Cisco router/device supports dual sim aggregation
CCIE Aspirant
Hi all,
Is there any cisco device that supports two or more LTE Sims both active at same time and perform active aggregation of both lte sim
Like i have one lte sim with 5mbps and other lte with 7mbps, so it should give me something near to 11 or 12mbps and if support ipsec s2s it will be plus.
Any other recommendations are welcomed
Thanks all
the Cisco 829 supports active/active. So do the Cisco 880G and 890G Series 4G LTE 2.0 Integrated Services Routers.
Below is a sample configuration for a dual modem/dual SIM active/active setup for the 829.
Make sure the data profiles set under the cellular controllers match the ones you have configured.
version 15.6
service internal
hostname 829-DUAL-Modem
boot-start-marker
boot system flash:/ir800-universalk9-mz.SPA.156-3.M0a
boot-end-marker
no aaa new-model
ethernet lmi ce
service-module wlan-ap 0 bootimage autonomous
ignition off-timer 900
ignition undervoltage threshold 9
no ignition enable
no ip domain lookup
ip inspect WAAS flush-timeout 10
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid IR829-2LTE-EA-BK9 sn FGL2032219N
redundancy
notification-timer 120000
controller Cellular 0
lte sim data-profile 3 attach-profile 1
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
controller Cellular 1
lte sim data-profile 1 attach-profile 1
interface GigabitEthernet0
no ip address
shutdown
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface Wlan-GigabitEthernet0
no ip address
interface GigabitEthernet5
no ip address
shutdown
duplex auto
speed auto
interface Cellular0/0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation slip
load-interval 30
dialer in-band
dialer string lte
dialer-group 1
no peer default ip address
async mode interactive
routing dynamic
interface Cellular1/0
ip nat outside
encapsulation slip
load-interval 30
dialer in-band
dialer string lte
dialer-group 1
routing dynamic
interface Cellular0/1
no ip address
encapsulation slip
interface Cellular1/1
no ip address
encapsulation slip
interface wlan-ap0
no ip address
interface Vlan1
interface Async0
no ip address
encapsulation scada
interface Async1
no ip address
encapsulation scada
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map CELL_0 interface Cellular0/0 overload
ip nat inside source route-map CELL_1 interface Cellular1/0 overload
ip route 0.0.0.0 0.0.0.0 Cellular1/0
ip route 0.0.0.0 0.0.0.0 Cellular0/0
dialer-list 1 protocol ip permit
route-map CELL_0 permit 10
match ip address 1
match interface Cellular0/0
route-map CELL_1 permit 10
match ip address 1
match interface Cellular1/0
ipv6 ioam timestamp
access-list 1 permit 192.168.1.0
control-plane
line con 0
stopbits 1
line 1 2
stopbits 1
line 3
script dialer lte
no exec
transport preferred lat pad telnet rlogin lapb-ta mop udptn v120 ssh
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
rxspeed 150000000
txspeed 50000000
line 4
no activation-character
no exec
transport preferred none
transport input all
line 8
script dialer lte
no exec
rxspeed 150000000
txspeed 50000000
line 9
script dialer lte
no exec
transport input all
rxspeed 236800
txspeed 118000
line 15
no exec
rxspeed 236800
txspeed 118000
line 1/3 1/6
transport output none
stopbits 1
line vty 0 4
login
transport input none
no scheduler max-task-time
Thanks georg for your reply
I have used these devices and i need something that has capabilities of aggregating two lte sims bandwidth and giving me aggregate bandwidth at Lan interfaces.
Like if sim1 is 5mbps and sim 2 is 7 mbps and both are lte so i need agggregate bandwidth of around 12mbps at lan ports
Your mentioned router functions more like load balancing or failover
You cannot bond cellular (3/4G) interfaces. Load balancing/sharing is the most you can achieve.
--> 4G LTE is a Layer 3 wireless WAN connection. Every 4G LTE connection is considered as a Layer 3 point-to-point
connection from the mobile node (ISR) to the packet gateway in the service provider core. Because of the mobile
architecture, the two cellular interfaces from the same service provider cannot be bonded at the radio level in a
similar way as the Multilink PPP.
