How is PBR applied under the interface of the configured service instance?
9813108aa
Hello
I tried to configure PBR under the interface of the configured service instance, but the route-map did not match any traffic anyway. What is the problem?
#sh acce
Extended IP access list 100
10 permit ip any any
#sh route-map
route-map 10, deny, sequence 10
Match clauses:
ip address (access-lists): 100
Set clauses:
Policy routing matches: 0 packets, 0 bytes
#show  int g1
interface GigabitEthernet1
no ip address
ip policy route-map 10
negotiation auto
no keepalive
no mop enabled
no mop sysid
spanning-tree link-type shared
service instance 1 ethernet
encapsulation untagged
l2protocol forward stp
service instance 10 ethernet
encapsulation dot1q 10
rewrite ingress tag pop 1 symmetric
storm-control unicast cir 20000
storm-control broadcast cir 20000
storm-control multicast cir 20000
Vincent
Richard Burts
Vincent
I am a bit puzzled about the very limited amount of config that you shared with us. Probably the most important thing that I notice is that you ip policy route-map 10 is applied to an interface that has no IP address. You can not successfully activate an IP activity like PBR on an interface that is not processing IP.
I am also surprised that the single instance in the route map uses deny. I certainly do not know much about your environment and what you are trying to achieve but I would have expected to use permit. And I am surprised that the acl does permit any any. If all traffic is to be processed by PBR then you do not need a match clause, and only need the set clause.
I also note that the interface references service instance 1 ethernet but then you show us service instance 10 ethernet
Rick
5 Replies 5
balaji.bandi
I am not sure you looking to configure PBR - your config does not match : here is example :
https://www.mustbegeek.com/configure-policy-based-routing-on-cisco-router/#.X1-7D2i2lhE
If you looking QoS please advise what is the goal ?
BB
Richard Burts
Vincent
Rick
Hello Rick
You noticed that my interface does not have an IP address, because this is dot1q 10 that uses instance to match, so there cannot be an IP address on this interface, but you say "You can not successfully activate an IP activity like PBR on an interface that is not processing IP."
I want to know how can I apply PBR under an interface without an IP address?
Vincent
Vincent
You ask how you can apply PBR to an interface that has no IP address. I do not believe that there is a way to do that. I have not done PBR with service instance, so can not offer advice based on experience. But I would guess that you would apply the ip policy command on whatever interface does get the IP address. Where is the IP for your service instance set up?
Rick
Hello Rick
Thank you for your reply. Now I know that PBR cannot be used on the interface set by the service instance. I use VPLS on ASR1000, so I will use the service instance, but I also use mpls-te, so I want to use PBR to select a specific tunnel As the next hop, I will look for other ways to work in this environment
Thanks again for your reply!
Vincent
