Cisco Router Dual ISP load balancing
kumarmh91282
Hi All,
Need your guidance and suggestion on the following requirement
One Cisco Router with Two Different ISPs (ISP assigned /32 IP addresses and would use Static route)
One Single subnet  LAN
Would like to configure Cisco Router for Load Balancing the ISPs  ( Active + Active) with Failover.
Thanks in advance for your Guidance and Suggestions.
Kumar
7 Replies 7
if you configure two static default routes, load balancing will be automatic. However, you need to confgure something to remove a static route when the respective ISP is down. What you could do is configure two IP SLAs, in conjunction with a couple of EEM scripts.
The config would look like below (IP addresses are arbitrary, obviously):
track 1 ip sla 1 reachability
track 2 ip sla 2 reachability
interface GigabitEthernet0/0
description Link to ISP 1
ip address 1.1.1.1 255.255.255.252
interface GigabitEthernet0/1
description Link to ISP 2
ip address 2.2.2.1 255.255.255.252
ip sla 1
icmp-echo 8.8.8.8 source-ip 1.1.1.1
frequency 5
ip sla schedule 1 start-time now life forever
ip sla 2
icmp-echo 8.8.8.8 source-ip 2.2.2.1
frequency 5
ip sla schedule 2 start-time now life forever
ip route 0.0.0.0 0.0.0.0 1.1.1.2
ip route 0.0.0.0 0.0.0.0 2.2.2.2
event manager applet ISP_1_DOWN
event track 1 state down
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 3.0 cli command "no ip route 0.0.0.0 0.0.0.0 1.1.1.2"
action 4.0 cli command "end"
event manager applet ISP_1_UP
event track 1 state up
action 3.0 cli command "ip route 0.0.0.0 0.0.0.0 1.1.1.2"
event manager applet ISP_2_DOWN
event track 2 state down
action 3.0 cli command "no ip route 0.0.0.0 0.0.0.0 2.2.2.2"
event manager applet ISP_2_UP
event track 2 state up
action 3.0 cli command "ip route 0.0.0.0 0.0.0.0 2.2.2.2"
Thanks for your reply,
Here we need to configure NAT, would configuring the NAT cause any issues in load balancing  ?
Does Router understand sessions ?
with NAT, the config would look like below:
ip nat outside
ip nat outside
interface Vlan 1
ip nat inside
ip sla 1
frequency 5
ip sla 2
frequency 5
action 5.0 cli command "clear ip nat translation *"
ip nat inside source route-map RM_ISP_1_NAT interface GigabitEthernet0/0 overload
ip nat inside source route-map RM_ISP_2_NAT interface GigabitEthernet0/1 overload
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
route-map RM_ISP_1_NAT permit 10
match ip address 101
match interface GigabitEthernet0/0
route-map RM_ISP_2_NAT permit 10
match interface GigabitEthernet0/1
Hi have similar configuration but find not only doesn't load balance it. It doesn't fail over unless I put an EEM script to remove the first ip nat inside source route-map xxxx interface g1 overload.
I am using 17.3
Hello Kumar
May i ask how you are actually connecting to your isps at the moment are you using dynamic routing such as an ospf or bgp
What routes are you receiving?
Kind Regards
Paul
Joseph W. Doherty
You might also want to investigate PfR (or whatever it's current replacement is, if any), as it can dynamically load balance and also deal with one of the paths failing.
for me divide the one LAN subnet to two and route each one through one ISP.
