Cisco Router for Hub spoke topology
aehtibarov
Hi guys,
I am looking for new cisco router that will take place of ISR 3925.
I will need more than 700 mb encryption throughput(3925 has only 250 mb), router should support dmvpn and for future capable , the router should support SDWAN.
I will use this router on Hub and Spoke connection as a hub device.
What would be your suggestion?
Mark Elsen
 - A generic starting point can be found here :
                  https://www.cisco.com/c/en/us/products/routers/router-selector.html
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
there is no direct replacement for the 3925. From what you say, the (new) 8300 series is probably what you need. It supports SD-WAN and also 5Gbps of IPSec traffic (allowing for future growth). DMVPN is supported as well.
https://www.cisco.com/c/en/us/products/collateral/routers/catalyst-8300-series-edge-platforms/datasheet-c78-744088.html?oid=dstetr023050
The ISR4400 series may also support your requirements.
Have a look at meraki, MX75 upwards would probably be applicable, is loaded with security (AMP,IDS/IPS,Content filtering etc.. High throughput inc vpn, even with all its security feature enabled, Supports multiple s2s vpn, and clients plus SDWAN. - Here
Kind Regards
Paul
