cisco router hangs
hi
my name is asim i am working as Network Administrator in govt sector in pakistan i have problem with cisco router 2900 series it gets hangs while booting i am sharing the current status of my router  i have attached the file as image of my router status
i will be oblige for this help regads
Jan 2 00:00:04.107: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module nam e = c2900 Next reboot level = ipbasek9 and License = ipbasek9
*Jan 29 04:02:46.679: c3600_scp_set_dstaddr2_idb(184)add = 80 name is Embedded-S ervice-Engine0/0
*Jan 29 04:03:04.371: %CTS-6-ENV_DATA_START_STATE: Environment Data Download in start state
*Jan 29 04:03:10.055: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed stat e to down
*Jan 29 04:03:10.055: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed stat e to down
*Jan 29 04:03:10.055: %LINK-3-UPDOWN: Interface Serial0/1/0, changed state to do wn
*Jan 29 04:03:10.055: %LINK-3-UPDOWN: Interface Serial0/1/1, changed state to do wn
*Jan 29 04:03:10.935: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, cha nged state to down
*Jan 29 04:03:11.151: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth ernet0/0, changed state to down
*Jan 29 04:03:11.151: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth ernet0/1, changed state to down
*Jan 29 04:03:11.155: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/ 0, changed state to down
*Jan 29 04:03:11.155: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/ 1, changed state to down
*Jan 29 04:03:12.963: %SYS-5-CONFIG_I: Configured from memory by console
*Jan 29 04:03:13.335: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, chan ged state to down
*Jan 29 04:03:14.315: %LINK-5-CHANGED: Interface Embedded-Service-Engine0/0, cha nged state to administratively down
*Jan 29 04:03:14.971: %LINK-5-CHANGED: Interface Serial0/1/0, changed state to a dministratively down
*Jan 29 04:03:14.971: %LINK-5-CHANGED: Interface Serial0/1/1, changed state to a dministratively down
*Jan 29 04:03:14.971: %LINK-5-CHANGED: Interface NVI0, changed state to administ ratively down
*Jan 29 04:03:15.363: %LINEPROTO-5-UPDOWN: Line protocol on Interface Embedded-S ervice-Engine0/0, changed state to down
*Jan 29 04:03:16.187: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth ernet0/0/0, changed state to down
*Jan 29 04:03:16.187: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth ernet0/0/1, changed state to down
*Jan 29 04:03:16.187: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth ernet0/0/2, changed state to down
*Jan 29 04:03:16.187: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth ernet0/0/3, changed state to down
*Jan 29 04:03:16.579: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M2, REL EASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 06-Feb-15 17:29 by prod_rel_team
7 Replies 7
Leo Laohoo
Remove all HWIC cards and reboot again.
i have remove all the network cables but still problem exist. Do you suggest its hardware problem which is creating problem regarding this
I never made any recommendation to remove the cables.
you have tole me to remove card
I recommend to remove all cards. Your response was "i have remove all the network cables".
Post the complete boot-up of the router.
i have attached the screeshot of router bootable hope it will help you to understand the problem
Thank you for attaching the screenshot.
I can see HWIC-2 and an ESS card installed during the bootup.
Look, if the cards can't be removed, contact Cisco TAC.
