Cisco Router Interface Issue
AI99
Visitor
I have a CISCO1921 router. The interface G0/0 is connected to a WAN modem dedicated for a layer 2 site to site connection. The connectivity to remote site (172.20.90.2/24) occasionally goes down.
Below is the interface config and statistics. Any hints ?
Thanks.
Config:
interface GigabitEthernet0/0
 description G0/0-WAN
 ip address 172.20.90.3 255.255.255.0
 no ip proxy-arp
 ip authentication mode eigrp 10 md5
 ip authentication key-chain eigrp 10 eigrp-keys
 duplex auto
 speed auto
Interface Statistics:
MAIN-RT#show interfaces g0/0
GigabitEthernet0/0 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is 30f7.0d99.7780 (bia 30f7.0d99.7780)
  Description: G0/0-WAN
  Internet address is 172.20.90.3/24
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full Duplex, 100Mbps, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input 00:02:38, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 323
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     541677827 packets input, 2252707648 bytes, 0 no buffer
     Received 13 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     600083342 packets output, 2788903018 bytes, 0 underruns
     0 output errors, 0 collisions, 21 interface resets
     0 unknown protocol drops
     18 lost carrier, 0 no carrier, 0 pause output
johnlloyd_13
Level 11
Level 11
hi,
can you try to hard code g0/0 to 100/full and observe?
Didn't work. I also tried shut - no shut the interface after changing config:
 no ip proxy-arp
 duplex full
 speed 100
end
MAIN-RT#sh int g0/0
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:01:54, output 00:00:04, output hang never
     600083581 packets output, 2788923099 bytes, 0 underruns
     0 output errors, 0 collisions, 22 interface resets
AI99
Visitor
CISCO881 Router - also connected to a WAN modem
interface FastEthernet4 (also connected to a WAN modem)
 description F4-WAN
 ip address 172.20.90.2 255.255.255.0
 no ip proxy-arp
 ip virtual-reassembly in
 duplex auto
 speed auto
REMOTE-RT#sh int f4
FastEthernet4 is up, line protocol is up
  Hardware is PQII_PRO_UEC, address is e02f.6dcc.2569 (bia e02f.6dcc.2569)
  Description: F4-WAN
  Internet address is 172.20.90.2/24
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 4
     597099205 packets input, 762830048 bytes
     Received 22598 broadcasts (0 IP multicasts)
     0 watchdog
     551570817 packets output, 4076380128 bytes, 0 underruns
     0 output errors, 0 collisions, 19 interface resets
     23 lost carrier, 0 no carrier
--> 18/23 lost carrier, 0 no carrier, 0 pause output
That usually indicates bad cabling...check for that and try and replace the cables...
