Cisco router selection
imranhoque11273
hi,
i am working on a customer router requirement.
below is the requirement. need urgent suggestion on which model (lowest) complies with it.
Form Factor
Rack Mountable Chassis
Environment
Maintain International Quality Environmental Safety Standard
Should have multiple Processor/CPU bases architecture with the dedicated control plane and service plane
Should provide traffic performance 350 Mbps or more
Memory
Minimum 4 GB DRAM & minimum 4 GB Flash
Interface
2 WAN Port (2x Copper Gigabit Ethernet) with 8 x 1 GE LAN Port and should support POE Module (4 POE r 2 POE+)
Management
1 x console, 1 x USB 2.0 Type A Port
Should support minimum 50 Mbps IPSec performance from day 1 which will be upgradable to 200 Mbps.
Should support static routes, RIP and RIPv2, OSPF, BGP, IS-IS, IGMPv3, PIMSM,SSM,RSVP, ACL, AVC and BFD
Should support LISP, Virtual Private LAN Services (VPLS), L2TPv3, MPLS & Ethernet over MPLS.
Network Service
IPv4, DNS, DHCP Clint, DHCP Server, DHCP Relay, NAT & AAA.
Should support hardware assisted VPN acceleration for crypto performance in future without any hardware change.
Security
Should support DES, 3DES, VPN compliant IPSec, AES-128 or AES-256 for encryption and RSA (748/1024/2048 bit) and ECDSA (256/384 bit) as authentication protocol in future without any hardware change
Should support PPPoE, Layer 2 Tunneling Protocol Version 3, Layer 2 and Layer 3 VPN, Ethernet Virtual Connections as well as IKEv2 IPSec based VPN, Crypto VPN, GRE VPN, site-to-site, dynamic multisite hub-and-spoke, multisite spoke and spoke, remote access software based VPN over IPv4 and IPv6, multicast traffic over the VPN in future without any hardware change.
Should support hardware assisted VPN acceleration for crypto performance.
Should support dynamic failover protocols such as virtual Router Redundancy Protocol (VRRP, RFC 2338)
QoS
Shaping, Policing, Per-Flow queening, Class-based queuing, Voice/Video/RTP QoS
Should support module OS on open platform with programmable and automation feature to support software defined WAN (i.c link optimization, application visibility/ detection, traffic load balancing, performance analysis for routing etc.
Mark Elsen
              - Checkout : https://www.cisco.com/c/en/us/products/routers/router-selector.html
   M.
Leo Laohoo
What is the budget for this router?
balaji.bandi
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-switch/221717-troubleshoot-dhcp-on-catalyst-9000-switc.html
Looking at the this you can use ASR or ISR or Cat 8K depends on the budget with additional slot :
https://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
Note : some models going to end of life soon, so check before you buy.
BB
