Cisco Router Setup 1841
khansen011
Hey everyone!
I need some help, i am new to using Cisco routers (as far as setting them up my self) so forgive me if this is something simple that i am over looking/not understanding.
I have a cable internet from cox.
They gave the the ip address below....
IP: 98.191.**.147
DG: 98.191.**.129
SNM 255.255.255.224
the ip address is the ip address that will connect the router to there modem.
On the lan side i have the following
Ip address 10.0.4.1
DG 10.0.4.254
SNM 255.255.255.0
What i need to do is take 10.0.4 network and tell it the inter net is at  the 90.191 network address and connect to the internet that way.
i have been watching some youtube videos on how to do this but there is something im missing and i cant figure it out.
If some one could help me shed some light on this i would greatly appreciate the help!!!!
5 Replies 5
khansen011
as of right now i get no internet connection on the 10 dot network.
outer#show ip interface brief
FastEthernet0/0 10.0.4.1 YES manual up up
FastEthernet0/1 98.191.**.147 YES manual up up
Vlan1 unassigned YES unset administratively down down
Router#
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip cef
no ipv6 cef
spanning-tree mode pvst
interface FastEthernet0/0
ip address 10.0.4.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 98.191.**.147 255.255.255.224
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
version 12.4
hostname Router
ip cef
no ipv6 cef
duplex auto
speed auto
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
In order to give access to Internet to your lan network, you need to do natting and add the default route
Below the config
Interface f0/0
Ip nat inside
Interface f0/1
Ip nat outside
Ip access-list extended NAT
Permit ip 10.0.4.0 0.0.0.255 any
ip nat inside source list NAT interface f0/1 overload
Ip route 0.0.0.0 0.0.0.0 98.191.**.129
how this is clear.
PS: don't forget to rate and mark as correct answer if this solved your issue
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
New Update as of 6/17/16
Router#
Router#show running
Router#show running-config
Building configuration...
Current configuration : 753 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
 ip address 10.0.4.254 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
 ip address 98.191.**.138 255.255.255.224
 ip nat outside
 duplex auto
 speed auto
ip classless
ip http server
ip nat inside source list 1 interface FastEthernet0/1 overload
access-list 1 permit 10.0.4.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
 login
end
Router#
i can ping 98.191.**.147 and get a 100% success but i try to ping 10.0.4.55 (the other pc) i get a 100% fail.
In other words i get single directional traffic
On your acl for nat you need to deny traffic from your lan network to your lan network. It had to be the first statement before the permit statement
Francesco
