Cisco routers for DC to Azure connectivity using MPLS/EXPRESSROUTE
Yuvi1983
I am looking basic Cisco routers with medium budget, the router required for Azure connectivity.
Requirement:
SFP/SFP+ Copper & FIBER ports (1G/10G)
BGP /IP Routing / redistribution / route-map/IP prefixes filtering
This router will have 1G link from ISP & required to configure the EXPRESSROUTE over MPLS to Azure.
Please suggest basic medium budget routers for my DC to Azure connectivity.
Thank you again
Yuvi
M02@rt37
Hello @Yuvi1983
See for a refurbished ASR 1002 router that can be a cost-effective solution.
When opting for refurbished equipment, ensure it comes from a reputable vendor offering a warranty/support.
Research authorized cisco resellers, compare prices & support options needed, and check technicals specifications to ensure the refurbished ASR 1002 meets your network’s specific needs.
Best regards
DanielP211
Hello!
I would go with the newer catalyst 8000 series, preferably 8300. The ASR1002 will soon go out of support, and since this is a DC deploymet it dosent make sense to go with older equipment.
The best option beeing C8300-1N1S-4T2X (its got 2x 10G ports and 4 gig UTP)- Since you won't be doing any IPsec/SD-WAN you can go with T0 licences on the DNA Advantage.
BR
****Kindly rate all useful posts*****
@DanielP211
While the C8300 offers advanced features and future-proofing, the cost-effectiveness of refurbished Cisco ASR 1002 routers makes them a practical choice for DC deployments with budget constraints.
The key here is to purchase from reputable vendors who provide warranties and support, ensuring the refurbished equipment meets the performance needs while significantly reducing costs.
While the ASR 1002 may be nearing its end of support, refurbished units often come with warranties and have been rigorously tested to meet original performance standards. These routers are well-suited for high-throughput environments, providing advanced MPLS support essential for data center to Azure connectivity using ExpressRoute over MPLS.
Sometimes organizations need to balance performance and budget, refurbished ASR 1002 routers deliver substantial savings while still providing the necessary capabilities for effective data center operations...
Best regards
