difference between IOS, IOS-XE and IOS XR
Ibrahim Jamil
Level 6
Level 6
Hello Freinds
What is the  difference between IOS, IOS-XE and IOS XR
 Answer for dummys pls :)
Thanks all guys
6 Replies 6
Joseph W. Doherty
If you're familiar with OSs, think of IOS as MS-DOS, IOS-XE as DESQview or VM/386, and IOS-XR as Linux or NT.
thanks freinds
Fahad Wasi
Hello
IOS-XE is basically a combination of a monolithic application and a linux kernel. IOS-XE is an advanced version of IOS and pls note that both IOS and IOS-XE share a lot of codes, meaning that both have similar codes unlike IOS-XR which is based on entirely different codings.
IOS-XR is based on QNX(QNX is a Unix type OS). The applications of IOS-XR has been seperated into different processes and if any one process stops or malfunctions ,the other processes are not effected.
David Amalorpavam
Please check the below link
https://www.youtube.com/watch?v=KWuiqX4TNTA
Dave Zacks, Distinguished Systems Engineer at Cisco, looks at the IOS-XE Evolution, which has changed from a monolithic OS, to a modularized IOS built on top of Linux. Its latest change is to deliver containerized application along side IOS, and to focus on programmability via APIs. Recorded at ...
rujipars_a
From practical experience, they are just 2 different IOS.
Depends on your luck whether you will have better or worse quality of life between the 2 OSes.
That's a compromized way to say about them.  My actual experience is worse with IOS-XR.
