Cisco RV042 VPN Multiple tunnels to one main
davidd1782
Hi, I am a employed at a credit union with 17 branches. We have a mpls circuit connecting the branches to our main office. I setup DSL as a backup connection.
I have 17 RV042 Cisco VPN Routers. I created a secure vpn tunnel for every branch to the main office. I made a delayed route in our main router to fail over to the VPN, in case the mpls failed.
Almost everything works great except our ATM's are required to connect to a router at our main office to a different subnet than the tunnel is connecting, therefore not routing through the tunnel. I've tried creating another tunnel but only works with one of the branches, cause I get a conflict at the main office when I try a second tunnel with the same ip network. Also I tried routing all the traffic through the vpn by putting in the address 0.0.0.0 subnet 0.0.0.0, at the branch site. But I can only do that for one branch, The Downtown Cisco won’t let me create another tunnel with that setting.
Any help would be appreciated
paolo bevilacqua
Wrong forum, use "small business - routers". You can move the post with the panel on the right.
However, from the description your infrastructure, you should use true Cisco routers, not Small Business / home models.
