Cisco RV340 supported LTE modem
Gipsy
i have planned that i build up the Cisco RV340 with failover LTE modem.
Can you give me the supported LTE(4G) modem for this router?
I'm in Germany and my mobile provider is Telekom and/or Vodafone.
The best thing if i can connect an external antenna.
regards
Gipsy
Hi @Gipsy
Why dont you use ISR800 that comes with 4G on it plus RV340 services?
-If I helped you somehow, please, rate it as useful.-
Hello
ok!
Do you me that i build the Cisco RV340 for all functions (direct connection to ISP, VPN, Firewall and so one..) and only the Cisco ISR 880 for WAN failover (LTE/4G).
That's right? Or only the Cisco ISR 880?
The Cisco ISR 880 is that here or?
https://www.cisco.com/c/en/us/products/collateral/routers/887-integrated-services-router-isr/data_sheet_c78_459542.html
Only ISR.  Of course, if you already had invested in RV340  then maybe is better keep it.
 I used to work with ISR829 and they have external antenna for 4G network which improve signal quality plus basic functionalities.
ok thanks!
Actually i don't buy the Cisco RV340 router, because i'm in the planning phase.
I think the ISR8XX has less functions as the Cisco RV340. Right?
Can you help me do find the right router to my needs?
My need are:
 - Dual WAN (primary: ISP; secondary (only for backup): integrated 4GE)
    I think an integrated LTE functionaltiy is besser that connect a usb drive
 - Firewall (Functions as RV340 are enough)
 - Port-Forwarding
 - SSL VPN
 - Create external VPN users on "router" and internal VPN user authenticate to our Active Directory
 - Use of Cisco AnyConnect
 - Posiblity for Site to Site VPN
 - Configuration what external vpn user can access to specifiy ressources (only to Server A, B...)
If you need more information, please ask me!
Thanks!
Gipsy
