Cisco Smart Licences
kwojtyra
I bought a security licences for my router. It was smart licences, what commands should I use to activate smart account in router? What commands should I use to activate the security licences?
I tried with license boot level securityk9 and reload the router.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None Smart License None
securityk9
appxk9
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None Smart License None
uck9 None Smart License None
securityk9 securityk9 Smart License securityk9
ipbase ipbasek9 Smart License ipbasek9
The current throughput level is unthrottled
Smart Licensing Status: Registration Not Applicable/Not Applicable
8 Replies 8
pieterh
the layout of your output is a bit garbled
but I see "Current Technology = Securityk9"
-> the license is preinstalled, you need not do anything
R4#sh license all
Smart Licensing is ENABLED
License Conversion:
Automatic Conversion Enabled: True
Status: Not started
Export Authorization Key:
Features Authorized:
<none>
Utility:
Status: DISABLED
Smart Licensing Using Policy:
Status: ENABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: cslu
Cslu address: <empty>
Proxy:
Not Configured
Miscellaneous:
Custom Id: <empty>
Policy:
Policy in use: Merged from multiple sources.
Reporting ACK required: yes (CISCO default)
Unenforced/Non-Export Perpetual Attributes:
First report requirement (days): 365 (CISCO default)
Reporting frequency (days): 0 (CISCO default)
Report on change (days): 90 (CISCO default)
Unenforced/Non-Export Subscription Attributes:
First report requirement (days): 90 (CISCO default)
Reporting frequency (days): 90 (CISCO default)
Enforced (Perpetual/Subscription) License Attributes:
First report requirement (days): 0 (CISCO default)
Report on change (days): 0 (CISCO default)
Export (Perpetual/Subscription) License Attributes:
Usage Reporting:
Last ACK received: <none>
Next ACK deadline: Jul 30 06:53:30 2024 UTC
Reporting push interval: 30 days
Next ACK push check: <none>
Next report push: Jul 31 06:55:30 2023 UTC
Last report push: <none>
Last report file write: <none>
Trust Code Installed: <none>
License Usage
securityk9 (ISR_1100_8P_Security):
Description: securityk9
Count: 1
Version: 1.0
Status: IN USE
Export status: NOT RESTRICTED
Feature Name: securityk9
Feature Description: securityk9
Enforcement type: NOT ENFORCED
License type: Perpetual
Product Information
UDI: PID:C1111X-8P,SN:xxxxxxxxxxxxx
Agent Version
Smart Agent for Licensing: 5.xxxxxxxxx
License Authorizations
Overall status:
Active: PID:C1111X-8P,SN:xxxxxxxxxx
Status: NOT INSTALLED
Purchased Licenses:
No Purchase Information Available
your output confirms my previous post
     Transport:
     Type: cslu
=> license usage is only reported, not retrieved
=> license is preinstalled, ==>> you need not do anything
I don't know is that Last ACK received should be with date? I see deadline date with one year. It should looks like this?
Usage Reporting:
yes that is correct, but...only if either
- the switch can directly contact cisco smart licensing portal on the internet
   using the default cslu url
- or you have an on-prem smart licensing satellite (wich is reachable by the switch)
   and you have configured reachability of this sattelite by
   -- DNS resolving
   -- configured the url
use a search engine for "smart licensing using policy"  for your device
most info will be the same as for the 9200 series switch in Cisco Content Hub - Smart Licensing Using Policy
Is it some evaluation version?
=> perpetual = means no expiration date ==> NO this is not an evaluation version
Hi @kwojtyra
Which router is it and which IOS?
Can you share the whole output if "show license" ?
