Cisco SOHO 97
tyzermans
have a bought a second hand Cisco SOHO 97 router and I have a problem with it. It's not possible for me to access the CRWS homepage when entering the URL http://10.10.10.1 in my browser. My NIC is configured to automaticaly receive an IP adresss from a DHCP server. In stead of receiving an address in the 10.10.10.x range, my IP adress is something like 192.168.1.64. What can I do to make it happen so I can access the CRWS and configure my router?
Thanks in advance...
Timothy Yzermans
pkhatri
Level 11
Level 11
Timothy,
It is possible that the router interface is configured with an address such as 192.168.1.1.
Can you try opening up http://192.168.1.1 ?
Pls do remember to rate posts.
Paresh
Hy,
you can connect with telnet, or with the consol cabel.
Use delet config function to set him back to factory defaults
and where do I have to enter the command delet config? at the command prompt or in some kind of program? thx in advance
no, that doesn't work. and my ip is a 169.x.x.x address wich means DHCP isn't working...
