cisco switch'port connected to ip phone and its configuration
sarahr202
Level 5
Level 5
Hi every body!
My book shows the following configurations:
switch# show running-config interface fastethernet 0/47
switchport access vlan 10
switchport mode access
switchport voice vlan 100
Would the above configuration will cause the port to be in trunk mode or access mode?
If in trunk mode why? because "switchport mode access" commands instructs the port to be in access mode and why use that command in the first place ?
thanks a lot!
2 Accepted Solutions
Giuseppe Larosa
Hello Sarah,
what I wrote in the other post applies here too
the port is in access mode
the command switchport trunk enc dot1q is not effective until the port is in access mode
these questions are done to create some confusion.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Sarah,
Hope to help
Giuseppe
Thanks for your reply Giuseppe and my apology for any confusion my questions may have caused.
Actually I posted the question in wrong forum and later Jon reminded me of my mistake so I just moved those questions into the right forum.
One thing I undesrtand if you hard-code the port as access port , it can not form trunk.The command" switchport mode access" does that but then you can not form trunk on that access port.
Any correction would be greatly appreciated.
lejoe.thomas
Level 3
Level 3
Thanks for the excellent link lejoe.
It has answered many questions
