Cisco XR router tacacs config
mustansirt
We are using TAC_PLUS as our tacacs server and we have made changes to Tacacs server for better control
so when user is in config mode he can run some commands while not execute some command
we were able to achieve this on XE router by enabling "aaa authorization config-commands "
but on XR platform router,above command is not supported so how can we achieve this.
curdubanbogdan
The command will be:
aaa authorization commands -> but only applies to user-exec mode.
This is all you can configure on the XR under aaa authorization:
commands
Configures authorization for all EXEC shell commands.
eventmanager
Applies an authorization method for authorizing an event manager (fault manager).
exec
Configures authorization for an interactive ( EXEC) session.
network
Configures authorization for network services, such as PPP or Internet Key Exchange (IKE).
subscriber
Sets the authorization lists for the subscriber.
default
Uses the listed authorization methods that follow this keyword as the default list of methods for authorization.
list-name
Character string used to name the list of authorization methods.
none
Uses no authorization. If you specify none, no subsequent authorization methods is attempted. However, the task ID authorization is always required and cannot be disabled.
local
Uses local authorization. This method of authorization is not available for command authorization.
group tacacs+
Uses the list of all configured TACACS+ servers for authorization.
group radius
Uses the list of all configured RADIUS servers for authorization. This method of authorization is not available for command authorization.
group group-name
Uses a named subset of TACACS+ or RADIUS servers for authorization as defined by the aaa group server tacacs+ or aaa group server radius command.
