vrf route leaking
please help
i need to go to vrf internet from global routing table in R6
need to ping 1.1.1.1 from R6 ???????????
R1
ip vrf Internet
rd 65:65
interface FastEthernet0/0
ip address 172.16.234.1 255.255.255.0
interface FastEthernet1/0
no ip address
interface FastEthernet1/0.3018
encapsulation dot1Q 3018
ip vrf forwarding Internet
ip address 10.40.82.162 255.255.255.252
interface FastEthernet1/0.3019
encapsulation dot1Q 3019
ip address 10.40.82.158 255.255.255.252
interface FastEthernet1/1
ip address 122.116.89.161 255.255.255.224
router eigrp 100
redistribute connected
redistribute static
network 10.40.82.156 0.0.0.3
auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.16.234.254
ip route vrf Internet 0.0.0.0 0.0.0.0 10.40.82.161
R6
ip address 10.40.82.157 255.255.255.252
duplex half
ip address 172.16.55.1 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router eigrp 100
redistribute static
network 10.40.82.0 0.0.0.255
auto-summary
ip route 172.16.66.0 255.255.255.0 172.16.55.254
R3
ip address 172.16.234.254 255.255.255.0
duplex half
ip address 172.16.151.254 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 172.16.234.1
Internet
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Loopback2
ip address 2.2.2.2 255.255.255.255
interface Loopback3
ip address 3.3.3.3 255.255.255.0
interface Loopback4
ip address 4.4.4.4 255.255.255.0
interface Loopback5
ip address 5.5.5.5 255.255.255.0
ip address 10.40.82.161 255.255.255.252
duplex half
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 10.40.82.162
6 Replies 6
Muhammad Awais Khan
You need to do Route leaking at R1 between Global Routing Table and VRF Internet. You can add below config just to make reachability between 1.1.1.1 and R6:
At R1:
ip vrf Internet
rd 65:65
route-target export 65:65
route-target import 65:65
ip route 1.1.1.1 255.255.255.255 FastEthernet1/0.3018
ip route vrf internet 10.40.82.156 255.255.255.252 FastEthernet1/0.3019
Please refer to below document for Route leaking between global Routing table and VRF.
https://www.cisco.com/c/en/us/support/docs/multiprotocol-label-switching-mpls/multiprotocol-label-switching-vpns-mpls-vpns/47807-routeleaking.html
not working
R6#ping 1.1.1.1
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Can you share routing tables of R1 at R6, including routing table of veg Internet
R6#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.40.82.158 to network 0.0.0.0
172.16.0.0/24 is subnetted, 3 subnets
D EX 172.16.234.0 [170/30720] via 10.40.82.158, 00:02:19, FastEthernet0/0
C 172.16.55.0 is directly connected, FastEthernet1/0
S 172.16.66.0 [1/0] via 172.16.55.254
10.0.0.0/30 is subnetted, 1 subnets
C 10.40.82.156 is directly connected, FastEthernet0/0
D*EX 0.0.0.0/0 [170/30720] via 10.40.82.158, 00:02:19, FastEthernet0/0
R1#sh ip route
Gateway of last resort is 172.16.234.254 to network 0.0.0.0
C 172.16.234.0 is directly connected, FastEthernet0/0
D EX 172.16.55.0
[170/30720] via 10.40.82.157, 00:02:38, FastEthernet1/0.3019
D EX 172.16.66.0
C 10.40.82.156 is directly connected, FastEthernet1/0.3019
S* 0.0.0.0/0 [1/0] via 172.16.234.254
Internet#sh ip route
Gateway of last resort is 10.40.82.162 to network 0.0.0.0
1.0.0.0/32 is subnetted, 1 subnets
C 1.1.1.1 is directly connected, Loopback0
2.0.0.0/32 is subnetted, 1 subnets
C 2.2.2.2 is directly connected, Loopback2
3.0.0.0/24 is subnetted, 1 subnets
C 3.3.3.0 is directly connected, Loopback3
4.0.0.0/24 is subnetted, 1 subnets
C 4.4.4.0 is directly connected, Loopback4
5.0.0.0/24 is subnetted, 1 subnets
C 5.5.5.0 is directly connected, Loopback5
C 10.40.82.160 is directly connected, FastEthernet0/0
S* 0.0.0.0/0 [1/0] via 10.40.82.162
There is no Route entry showing in R1 for 1.1.1.1, i belive we may need to add next hop also in addition to interface for the routes related tovrf interfaces. can you update previously added route to below for 1.1.1.1 :
ip route 1.1.1.1 255.255.255.255 FastEthernet1/0.3018 10.40.82.161
Also send output for show ip route vrf internet at R1.
Hello
You need to tell the vrf router about its networks in the vrf  and as such it will then allow communication between global routing table and the vrf
Example to allow internet vrf to reach R6 using your existing static/dynamic routing
Internet rtr-
no ip route 0.0.0.0 0.0.0.0 10.40.82.162
ip route 10.40.82.156 255.255.255.252 10.40.82.162<static route for R6 subnet
ip route 122.116.89.160 255.255.255.224 10.40.82.162<static route for R2 subnet
ip route 172.16.55.0 255.255.255.0 10.40.82.162 <static route for R6 subnet
R6 -
no ip route 172.16.66.0 255.255.255.0 172.16.55.254
router eigrp 100
no auto-summary
R1 - vrf rtr
router eigrp 100
no redistribute connected
no redistribute static
no auto-summary
no ip route 0.0.0.0 0.0.0.0 172.16.234.254
no ip route vrf Internet 0.0.0.0 0.0.0.0 10.40.82.161
ip summary-address eigrp 100 0.0.0.0 0.0.0.0 1 < default route for r6 via eigrp
ip route 0.0.0.0 0.0.0.0 FastEthernet1/0.3018 10.40.82.161 <default route towards internet rtr for global route table
ip route 10.40.82.160 255.255.255.252 FastEthernet1/0.3018 <static route for global route table to know about its vrf interface
ip route 172.16.151.0 255.255.255.0 172.16.234.254 <static route for global route tablet to know about its vrf interface
ip route vrf Internet 0.0.0.0 0.0.0.0 10.40.82.161 global <default route towards internet rtr for vrf route table
ip route vrf Internet 10.40.82.156 255.255.255.252 10.40.82.157 global<static vrf route for R6 subnet
ip route vrf Internet 172.16.55.0 255.255.255.0 10.40.82.157 global<static vrf route for R6 subnet
Kind Regards
Paul
