cisco2811 : not enter any key in rommon
jogilsang
hello all :)
i have a cisco2811
but, fatal(?) problem exec!!
situation this.
consol cable connected -  power on - flash memory(64mb, new) - putty
and i see rommon 1 >
but, does not enter any key.
belived? does not enter any key.
i want to use rommon mode! and upgrade c2800nm-advipservicesk9-mz.124-24.T6.bin
to ciscoflashmemory(64mb)
more information below
please answer my question
System Bootstrap, Version 12.4(13r)T5, RELEASE SOFTWARE (fc1)
Copyright (c) 2007 by cisco Systems, Inc.
Initializing memory for ECC
c2811 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Upgrade ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
loadprog: error - Invalid image for platform
e_machine = 134, cpu_type = 135
boot: cannot load "flash:"
rommon 1 >
jogilsang
i solved it!
i have a problem console cable.
i change it new.
This is not easy to doubt. Because different products good use it.
