08-10-2015 01:20 AM - edited 03-05-2019 02:02 AM
Hi everyone,
I wanted to configure a Cisco 2901 for a ADSL connection but without success. I didn´t event got a link on the atm interface.
I tried the same connection with my a Cisco 870 and there I´ve got a connection. So I guess my DSL link is ok.
Can someone help me please to find my mistake?
Best regards
Robert
controller Cellular 0/0
controller VDSL 0/2/0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.11.0.1 255.255.255.128
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address dhcp
duplex auto
speed auto
interface GigabitEthernet0/1/0
no ip address
shutdown
duplex auto
speed auto
interface ATM0/2/0
no ip address
no atm ilmi-keepalive
interface ATM0/2/0.1 point-to-point
pvc 1/32
pppoe-client dial-pool-number 1
interface Ethernet0/2/0
no ip address
shutdown
interface Dialer1
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxx
ppp chap password 7 xxxx
ppp pap sent-username 0xxx
ppp ipcp dns request
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source route-map NAT_DSL interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended DSL_ACCESSLIST
permit ip 10.11.0.0 0.0.255.255 any
dialer-list 1 protocol ip permit
route-map NAT_DSL permit 10
match ip address DSL_ACCESSLIST
match interface Dialer1
control-plane
08-10-2015 04:24 AM
Hello
Try to configure dsl operating-mode auto (or choose the appropriate ADSL mode if you're sure) under the controller VDSL0/2/0 configuration sub-mode.
You may also want to configure the encapsulation to be used under the pvc1/32 configuration sub-mode: encapsulation aal5mux ppp dialer if using multiplexing. The default is to use AAL5+LLC/SNAP. Also please make sure that your VPI/VCI is correct.
Can you please provide the output of the following commands:
show controllers VDSL 0/2/0
show controllers atm 0/2/0
show atm interface atm 0/2/0
show atm pvc interface atm 0/2/0
show atm pvc 1/32
Best regards,
Martin
08-10-2015 04:49 AM
Hi Martin,
The idea with the dsl mode showed me the right way. My controller is a EHWIC-VA-DSL-A but what I need is an EHWIC-VA-DSL-B because I need EHWIC over ISDN.
Now I have to change the module. Thank you for you answer.
best regards,
Robert
