I have a remote site that has a 2851 currently with a single ISP and VPN site-to-site back to my HQ. I would like to add a second ISP at the remote site for fail-over as the Internet connection at the location is somewhat unstable. My HQ is fully redundant already with dual ISPs and eBGP. To comply with corporate policy I tunnel all traffic back to HQ for inspection, content filtering, SSL decryption, etc. I'd prefer to use a tunnel interface with this setup as I can do more with ACLs and security opposed to crypto-maps.
Is it possible in the IOS to do the following?
I could do this with 2 routers and HSRP but that would involve changing the way things work at HQ with the routing and I would like to avoid that if possible to not introduce more changes. Any thoughts on how to do it would be appreciated. Thanks in advance.
HI did you get the solution ?
i am also looking forward for a solution to get the VPN fail over, right now have 2 routers each connected to different ISP with static ip. INternet fail over is working fine and even VPN tunnel is also fine but i do not know how to configure the VPN failover... do you have any idea about it ?
Sandy
