11-28-2012 03:36 AM - edited 03-04-2019 06:15 PM
I want to capture packet on gi0/0 of PE1 in order to show customer that all his traffic is encapsulated and transmitted by L2VPN (ldp signaling) in his lab.
CE1-----------(g0/1)PE1(g0/0)------------PE2-----------CE2
PE1 and PE2 are Cisco3945 and L2VPN is working well. I tried cisco RITE(Router IP Traffic Export Packet Capture) feature, but the output was not what I expected. I tried both export mode and capture mode. Only LDP hello message I got, looks like RITE is only interested in IP packet. Monitor session wasn't effective as well because it is not a switch.
Is there any other way/workaround to capture customer's traffic encapsulated in L2VPN?
What I did on PE1 when I was trying RITE export mode:
ip traffic-export profile test
bidirectional
interface GigabitEthernet0/2
mac-address e411.5b44.3a6d
ip address 10.1.2.1 255.255.255.0
interface GigabitEthernet0/0
ip traffic-export apply test
Gi0/2 connected my PC(10.1.2.2) with wireshark installed.
Many thanks.
Jerry Fan
11-28-2012 05:46 AM
I don't think there is any packet capturing mechanism availble in cisco routers to captue MPLS packet
You can connect a switch in middle of PE1 and PE2 and sniff the packets
Thank you
Raju
11-28-2012 11:41 AM
Hi Jerry,
I agree with Raju.
Catalyst Switched Port Analyzer (SPAN) Configuration Example
HTH.
Please rate any helpful posts
11-28-2012 11:39 PM
Many thanks, all. I originally don't want to use switch, so that can show my "powerful technical skill". Ahah. But.........
As another expert suggested, I tried another way 'monitor capture' today, but failed. 'monitor capture' is only interested in ipv4 and ipv6. Maybe the IOS in Cisco3945 isn't same as the IOS in Cat6500 or Cisco7600 or GSR/CSR.
See following:
Router_MPS_TEST_A#monitor capture ?
buffer Control Capture Buffers
point Control Capture Points
Router_MPS_TEST_A#monitor capture po
Router_MPS_TEST_A#monitor capture point ?
associate Associate capture point with capture buffer
disassociate Dis-associate capture point from capture buffer
ip IPv4
ipv6 IPv6
start Enable Capture Point
stop Disable Capture Point
Router_MPS_TEST_A#monitor capture point ip ?
cef IPv4 CEF
process-switched Process switched packets
Router_MPS_TEST_A#monitor capture point ip p
Router_MPS_TEST_A#monitor capture point ip process-switched ?
WORD Name of the Capture Point
Router_MPS_TEST_A#monitor capture point ip process-switched test-point ?
both Inbound and outbound and packets
from-us Packets originating locally
in Inbound packets
out Outbound packets
Router_MPS_TEST_A#monitor capture point ip process-switched test-point b
Router_MPS_TEST_A#monitor capture point ip process-switched test-point both ?
At last, I had to insert a switch in the middle of two cisco3945 and configured port span. That worked very well.
Jerry Fan
