CISCO3945E/K9 - password recovery disabled / break into ROM issue
Costinel Socol
Dear All,
Can you Please help me with some advice regarding the following issue?
We have a CISCO3945E/K9 for which password recovery functionality was disabled.
I have tried to factory reset the router but i'm not able to break into ROM.
I have tried everything possible, even to remove the flash card but i'm not able to break into ROM...
Do you have any idea how cold I reset the router to factory default?
System Bootstrap, Version 15.1(1r)T5, RELEASE SOFTWARE (fc1)
Copyright (c) 2012 by cisco Systems, Inc.
Total memory size = 1024 MB - DIMM0 = 512 MB, DIMM1 = 512 MB
CISCO3945-CHASSIS with C3900-SPE250/K9 with 1048576 Kbytes of main memory
Main memory is configured to 72/72(dimm 0/1) bit mode with ECC enabled
Readonly ROMMON initialized
PASSWORD RECOVERY FUNCTIONALITY IS DISABLED
Booting c3900e-universalk9-mz.SPA.155-3.M6.bin ...
Any advice will be much appreciated!
Many thanks in advance!
Kind regards,
Costinel S.
7 Replies 7
when the image is decompressing:
Self decompressing the following image:
################################################[OK]
Are you trying the break sequence within 5 seconds of seeing this line ?
Hi Georg,
While trying to break sequence when mentioned prompt appeared nothing is happening.. booting process is not interrupted, it continues until it's finished.
Thanks !
Kind regards,
Costinel S.
check if your flash actually contains a valid IOS image (dir flash:)...
omz
Leo Laohoo
Go HERE.
Thanks !
But it does't work...
The sequence after that site recommend to issue the brake command does not appear on CISCO3945E/K9 booting process.
Kind regards,
Costinel S.
