CISCO433/K9 NIM module support
raghav.rai
Does Cisco 4331/k9 supports both NIM-2GE-CU-SFP and NIM-ES2-4 at the same time ?
I have a requirement of both switch ports and additional routed ports on 4331 in a lab set-up.
Also routed ports on NIM-2GE-CU-SFP supports BDI ?
Raghavendra
balaji.bandi
I have not tested, but technically the model support both modules, as long as you have free slot avalable should be working as expected.
BB
