Cisco892/K9 DHCP Server don't work?
jmmgrodrigues
I Have interface Gi0 as nat outside and interface Fa8 with no ip address.
I have created 3 subinterfaces on Fa8, listed below.
How can I make such that each of them DHCP server working?
int gi0
ip address 10.0.0.2 255.255.255.252
ip nat outside
int fa8.10
description VLAN10-Data
encapsulation dot1Q 10
ip address 10.0.10.14 255.255.255.240
ip nat inside
int fa8.20
description VLAN20-IPTV
encapsulation dot1Q 20
ip address 10.0.20.6 255.255.255.248
ip nat inside
int fa8.30
description VLAN30-Guests
ip address 10.0.30.6 255.255.255.248
ip nat inside
ip dhcp excluded-address 10.0.10.14
ip dhcp excluded-address 10.0.20.6
ip dhcp excluded-address 10.0.30.6
ip dhcp pool Vlan 10
network  10.0.10.0 255.255.255.240
default-router  10.0.10.14
ip dhcp pool Vlan 20
network  10.0.20.0 255.255.255.240
default-router  10.0.20.6
ip dhcp pool Vlan 30
network  10.0.30.0 255.255.255.240
default-router  10.0.30.6
Nat is working well, I can ping/traceroute outside of the lan! I am not getting DHCP Server to assign addresses to the pc's through the ports Fa0 to 7. Can you help me, please?
Seb Rupik
Hi there,
If you want to use fa0-7 as switchports then you will need to change your configuration from using routed sub-interfaces to SVIs:
int fa8.10
  no ip address
  no ip nat inside
int fa8.20
  no ip address
  no ip nat inside
int fa8.30
  no ip address
  no ip nat inside
int vlan 10
  ip nat inside
int vlan 20
  ip nat inside
int vlan 30
  ip nat inside
int range fa0-7
  switchport mode access
  switchport access vlan10
  spanning-tree portfast
We will leave the rest of the fa8 sub-interface config so you can use that as a trunk link to connect to a switch.
cheers,
Seb.
Seb Rupik
Hi there,
int fa8.10
  no ip address
  no ip nat inside
int fa8.20
  no ip address
  no ip nat inside
int fa8.30
  no ip address
  no ip nat inside
int vlan 10
  ip nat inside
int vlan 20
  ip nat inside
int vlan 30
  ip nat inside
int range fa0-7
cheers,
Seb.
Thanks Seb.! It worked! I did not understand how to get there. :)
