Unable to ping outside interface from outside Cisco ISR4400
In my current setup I have an ISR4400 directly connected to the ISP. I am able to connect to the internet from the inside and ping any public IP as well as the outside interface IP.. However, I can not ping the outside interface from an outside IP. I am able to ping the next hop router from outside as well.
I have created inside / outside zones and applied the relevant policy and class maps. I also created policies and maps and pairs for the self zone as a test in case for some reason the router was not doing the default behaviour.
For now my class-map refers to an ACL that only allows ICMP from outside to inside.
I saw on another thread about adding a route to the outside interface....is this the issue? If so where is it added as I was unable to add a route outside.
Thanks in advance
orange#show running-config
Building configuration...
Current configuration : 4014 bytes
! Last configuration change at 12:11:21 UTC Mon Apr 16 2018 by xxx
version 15.5
no platform punt-keepalive disable-kernel-core
hostname orange
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 $1$DRvZ$GDXrCeYcWavEfyoHWYH6j.
enable password xxxxxx
aaa new-model
aaa authentication login userauthen local
aaa authorization exec default local
aaa authorization network groupauthor local
aaa session-id common
ip domain name rtr.xxxxxx.com
ip dhcp excluded-address 10.0.25.1 10.0.25.49
ip dhcp pool internal-lan
import all
network 10.0.25.0 255.255.255.0
default-router 10.0.25.1
dns-server 8.8.8.8
domain-name xxxx-xxxx.com
subscriber templating
license udi pid ISR4451-X/K9 sn FOC211587U8
license boot level securityk9
username xxxxx privilege 15 password 0 xxxxxx
redundancy
mode none
vlan internal allocation policy ascending
class-map type inspect match-any outside-inside-class
match access-group name outside-inside-acl
class-map type inspect match-any outside-self-class
match protocol icmp
match protocol https
match protocol http
match protocol dns
match protocol tcp
class-map type inspect match-any self-outside-class
match protocol icmp
match protocol http
match protocol dns
match protocol tcp
class-map type inspect match-any myinspectclass
match protocol http
match protocol tcp
match protocol dns
match protocol icmp
policy-map type inspect self-outside-policy
class type inspect self-outside-class
inspect
class class-default
policy-map type inspect outside-inside-policy
class type inspect outside-inside-class
inspect
class class-default
policy-map type inspect outside-self-policy
class type inspect outside-self-class
inspect
class class-default
policy-map type inspect myinspectpolicy
class type inspect myinspectclass
inspect
class class-default
zone security inside
description LAN
zone security outside
description Internet
zone-pair security in-out source inside destination outside
service-policy type inspect myinspectpolicy
zone-pair security out-self source outside destination self
service-policy type inspect outside-self-policy
zone-pair security outside-to-inside source outside destination inside
service-policy type inspect outside-inside-policy
zone-pair security self-outside source self destination outside
service-policy type inspect self-outside-policy
interface GigabitEthernet0/0/0
ip address 10.0.25.1 255.255.255.0
ip nat inside
zone-member security inside
negotiation auto
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/3
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/1/0
ip address 84.207.207.94 255.255.255.252
ip nat outside
zone-member security outside
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
ip nat inside source list 100 interface GigabitEthernet0/1/0 overload
ip forward-protocol nd
ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 84.207.207.93
ip scp server enable
ip access-list extended outside-inside-acl
permit icmp any any
access-list 100 permit ip any any
control-plane
line con 0
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0 4
0 Replies 0
