class-map and policy-map question
hugh2_nguyen
I'm using Cisco 3825 router and trying to set reserved bandwidth for different priority ingress traffic from different interface. I have high priority traffic comming into interface fa2/14 at rate ~1Mbps and low priority traffic comming into interface g2/0 at rate ~7Mbps. I configured the following classes and policy-map to reverse 2Mbps for Fa2/14 and 7Mbps for G2/0 over the congested Ethernet port fa2/0 (i.e. Tunnel0), which is the output Ethernet interface to the WAN:
class-map match-any high
match input-interface FastEthernet2/14
class-map match-any low
match input-interface GigabitEthernet2/0
policy-map TRAFFIC
class high
bandwidth 2000
class low
bandwidth 7000
policy-map FQ
class class-default
fair-queue
interface Tunnel0
bandwidth 10000
ip address 10.1.1.1 255.255.255.0
load-interval 30
ipv6 enable
ospfv3 instance 64 network manet
ospfv3 1 area 0 address-family ipv4 instance 64
tunnel source FastEthernet2/0
tunnel destination 142.x.x.10
interface FastEthernet2/0
no switchport
bandwidth 10000
ip address 192.x.x.10 255.255.255.0
load-interval 30
service-policy output TRAFFIC
The class-map and policy-map don't seem to work. The "show policy-map int f2/0" showed that int f2/0 is still running on class-default:
Router6-w-AXP#show policy-map int f2/0
FastEthernet2/0
Service-policy output: TRAFFIC
Class-map: high (match-any)
0 packets, 0 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: input-interface FastEthernet2/14
0 packets, 0 bytes
30 second rate 0 bps
Queueing
queue limit 64 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 0/0
bandwidth 2000 kbps
Class-map: low (match-any)
0 packets, 0 bytes
Match: input-interface GigabitEthernet2/0
0 packets, 0 bytes
Queueing
bandwidth 7000 kbps
Class-map: class-default (match-any)
11971181 packets, 8583659812 bytes
30 second offered rate 10602000 bps, drop rate 0 bps
Match: any
(pkts output/bytes output) 3165/620740
Would you please give me some advice on a proper way to configure reserved bandwidth over the congested tunnel. Attached are running-config file and show policy-map data.
Thanks!
Hugh
18 Replies 18
hugh2_nguyen
Here're attachments
Hi Hugh.
Does all traffic go out of the tunnel and nothing goes out the physical interface? It might be that all the class-default traffic is actually GRE traffic sourced from f2/0 so none of it will match your other classes as the traffic is not coming from those interfaces.
You can see if this is right or not by adding between class 'low' and class-default a class which matches all GRE traffic. Then if you check your 'show policy-map' command you can see if it is getting hits.
Have you tried putting the service policy on the tunnel interface? Not sure if this is possible, can't test in a the lab at the mo.
Cheers
Simon
Simon,
Thanks for the quick reply.
Interface Tunnel0 would not accept the "service-policy output TRAFFIC" and the error message was "Weighted Fair Queueing feature is not supported in user defined class of parent level policy." I don't know if a child level polity for the tunnel can work around the issue.
Yes, the traffic does seem like comming from GRE tunnel. I added a class "gre" to match protocol GRE traffic, not sure if that was what you suggested but here're the configuration:
class-map match-any gre
match protocol gre
policy-map TRAFFIC
class high
bandwidth 200
class low
bandwidth 700
class gre
bandwidth 9000
policy-map FQ
class class-default
fair-queue
The "show policy-map int f2/0" did show hit on class gre.
Would you please give me some advice on any other work around method. Thanks.
Hugh
Hi Hugh
looks like the only option supported on a gre tunnel is shaping
try adding PARENT to the tunnel interface
policy-map PARENT
class-default
shape average 100000000
service-policy TRAFFIC
Simon,
Thanks for the input. I added the policy-map PARRENT but class high and class low still did not get any hit. Here's current interfaces and policy configuration along with "show policy-map int t0" data:
policy-map TRAFFIC
class high
bandwidth 2000
class low
bandwidth 7000
policy-map FQ
class class-default
fair-queue
policy-map PARENT
class class-default
description HIGH PRIORITY INGRESS TRAFFIC
no switchport
ip address 192.168.12.40 255.255.255.0
load-interval 30
ipv6 enable
description LOW PRIORITY INGRESS TRAFFIC
no switchport
ip address 192.168.2.40 255.255.255.0
load-interval 30
ipv6 enable
interface Tunnel0
bandwidth 10000
load-interval 30
ipv6 enable
service-policy output PARENT
description EGRESS TRAFFIC TO THE WAN
no switchport
bandwidth 10000
load-interval 30
Router6-w-AXP#show policy-map int t0
Tunnel0
Service-policy output: PARENT
1924994 packets, 1358517804 bytes
30 second offered rate 10065000 bps, drop rate 0 bps
Match: any
Queueing
shape (average) cir 10000000, bc 40000, be 40000
target shape rate 10000000
Service-policy : TRAFFIC
0 packets, 0 bytes
0 packets, 0 bytes
Queueing
bandwidth 2000 kbps
0 packets, 0 bytes
0 packets, 0 bytes
Queueing
bandwidth 7000 kbps
30 second offered rate 10066000 bps, drop rate 0 bps
Match: any
Joseph W. Doherty
One reason your original policy map might not be working as expected because the traffic you're trying to match against is encapsulated within GRE packets. (Confirmed by your 3rd post?) What might correct this is usage of "qos pre-classify" on the tunnel interface. (The reason I write "might", I'm not positive about usage of matching against input interfaces within the class-maps. Which also might be the problem within your 4th post.)
What you might also try is using an input service policy to ToS mark (different markings) the traffic arriving on the two "special" interfaces and then on the outbound policy match against those markings. Unless you need to shape the tunnel slower, you can have the policy again on the outbound interface. You won't need the pre-classify since the ToS markings will be copied to the GRE header. The only issues are what ToS marking to use and whether you want to pass them along.
e.g. (NB: syntax might be incorrect)
policy-map high
class class-default
set dscp 2
policy-map low
class class-default
set dscp 1
match dscp 2
match dscp 1
policy-map TRAFFIC
class high
bandwidth 2000
set dscp be
class low
bandwidth 7000
set dscp be
policy-map FQ
class class-default
!btw, FQ on many platforms can skew the other class bandwidth reservations
fair-queue
service-policy input low
service-policy input high
Hi Joe,
It finally worked but not as expected. I don't know what I mucked around with that got it to work. I still see class low gets more than 7Mbps bandwidth and class high only get about 1Mbps. I changed bandwidth to priority and saw the same bandwidth ratio. I'll try your suggestion and let you know the result.
Here's show policy data with current configuration:
Router6-w-AXP#sh policy-map int t0
Tunnel0
6008931 packets, 4240298312 bytes
30 second offered rate 10498000 bps, drop rate 0 bps
Match: any
Queueing
queue stats for all priority classes:
303905 packets, 214533040 bytes
30 second offered rate 1061000 bps, drop rate 0 bps
104215 packets, 73575172 bytes
30 second rate 1061000 bps
Priority: 2000 kbps, burst bytes 50000, b/w exceed drops: 0
1842540 packets, 1300348088 bytes
30 second offered rate 9436000 bps, drop rate 0 bps
738719 packets, 521343420 bytes
30 second rate 9436000 bps
Priority: 7000 kbps, burst bytes 175000, b/w exceed drops: 0
3862466 packets, 2725403064 bytes
Match: any
Router6-w-AXP#
Could you post the "working" policy?
As to seeing a class obtain more bandwidth then the defined bandwidth statement, that's normal for non-LLQ classes. Their bandwidth statements defined a minimum, not maximum. Even with your LLQ, the implicit policer only engages if there's congestion and the defined rate is exceeded. (Also note that policing can be "rough" on traffic; something you might not want. Shaping is often a better approach.)
Depending on your requirements, physical interfaces QoS generally behaves better than a shaper (which QoS on the tunnel appears to require).
Here's the policy:
policy-map DATA
class high
priority 8000
class low
priority 1000
policy-map FQ
class class-default
fair-queue
policy-map PARENT
class class-default
service-policy DATA
With or without the command line "qos pre-classify" the policy worked the same. Class low still competed with class high for bandwidth during congestion:
interface Tunnel0
bandwidth 10000
load-interval 30
ipv6 enable
Tunnel0
Match: any
Queueing
Match: any
Router6-w-AXP#
"With or without the command line "qos pre-classify" the policy worked the same."
That's because your policy is configured on the tunnel. The purpose of the command is to allow QoS to "see" pre-tunnel traffic packet headers on the interface that's sending the tunnel traffic.
"Class low still competed with class high for bandwidth during congestion:"
Unclear what you mean. Results look alright for this configuration altough the policy itself, with the two LLQ classes may not. Then again, you haven't described what you want to accomplish.
Hi Joe,
I want to reserve a minimum tunnel bandwidth of 2Mbps for class high (i.e. traffic from interface fa2/14). I tried either "bandwidth" or "priority" but did not acchieved the minimum reserved bandwidth of 2Mbps for class high. I would like to limit class low bandwidth (i.e. traffic from g2/0) to below 8Mbps over the tunnel. Thanks.
Hugh
You might need to "define" what you consider reserving bandwidth. The priority or bandwidth commands do reserve bandwidth but perhaps not as you expect.
What might be a cause of confusion, such bandwidth reservations don't normally preclude other traffic from using that bandwidth if the traffic for that class isn't using all of it. (Normally this is a good thing).
If you really wanted to limit your other class to not exceed 8 Mbps, you would use a shaper or policer. (However, if you can priorize and/or guarantee bandwidth for other classes, this, restricting bandwidth, I suggest, isn't often the optimal approach for taking advanage of WAN bandwidth.)
e.g.
policy-map sample
class high
bandwidth 2000
class low
bandwidth 8000
shape average 8000000
Joe,
I have a highly congested WAN; that is if I let class low goes freely then it would clog up the whole 10Mbps WAN. I really need to throttle class low bandwidth down to no higher than 8Mbps.
Here's the DSCP policy map per your suggestion. The router wouldn't accept command "set dscp be":
match dscp 2
match dscp 1
policy-map high
class class-default
set dscp 2
policy-map TRAFFIC
class high
bandwidth 2000
class low
bandwidth 7000
shape average 7000000
policy-map low
class class-default
set dscp 1
no switchport
bandwidth 1544
load-interval 30
ipv6 enable
no switchport
load-interval 30
ipv6 enable
description WAN INTERFACE
no switchport
bandwidth 10000
load-interval 30
interface Tunnel0
bandwidth 10000
load-interval 30
ipv6 enable
And here's the show policy-map:
Router6-w-AXP#sh policy-map int f2/0
FastEthernet2/0
474505 packets, 341640510 bytes
30 second offered rate 1148000 bps, drop rate 0 bps
Match: dscp 2
30 second rate 1148000 bps
Queueing
bandwidth 2000 kbps
3320165 packets, 2388688270 bytes
30 second offered rate 9477000 bps, drop rate 0 bps
Match: dscp 1
30 second rate 9477000 bps
Queueing
bandwidth 7000 kbps
shape (average) cir 7000000, bc 28000, be 28000
target shape rate 7000000
184 packets, 35258 bytes
Match: any
(pkts output/bytes output) 125/25060
Router6-w-AXP#
