class-map and policy-map question
hugh2_nguyen
I'm using Cisco 3825 router and trying to set reserved bandwidth for different priority ingress traffic from different interface. I have high priority traffic comming into interface fa2/14 at rate ~1Mbps and low priority traffic comming into interface g2/0 at rate ~7Mbps. I configured the following classes and policy-map to reverse 2Mbps for Fa2/14 and 7Mbps for G2/0 over the congested Ethernet port fa2/0 (i.e. Tunnel0), which is the output Ethernet interface to the WAN:
class-map match-any high
match input-interface FastEthernet2/14
class-map match-any low
match input-interface GigabitEthernet2/0
policy-map TRAFFIC
class high
bandwidth 2000
class low
bandwidth 7000
policy-map FQ
class class-default
fair-queue
interface Tunnel0
bandwidth 10000
ip address 10.1.1.1 255.255.255.0
load-interval 30
ipv6 enable
ospfv3 instance 64 network manet
ospfv3 1 area 0 address-family ipv4 instance 64
tunnel source FastEthernet2/0
tunnel destination 142.x.x.10
interface FastEthernet2/0
no switchport
bandwidth 10000
ip address 192.x.x.10 255.255.255.0
load-interval 30
service-policy output TRAFFIC
The class-map and policy-map don't seem to work. The "show policy-map int f2/0" showed that int f2/0 is still running on class-default:
Router6-w-AXP#show policy-map int f2/0
FastEthernet2/0
Service-policy output: TRAFFIC
Class-map: high (match-any)
0 packets, 0 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: input-interface FastEthernet2/14
0 packets, 0 bytes
30 second rate 0 bps
Queueing
queue limit 64 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 0/0
bandwidth 2000 kbps
Class-map: low (match-any)
0 packets, 0 bytes
Match: input-interface GigabitEthernet2/0
0 packets, 0 bytes
Queueing
bandwidth 7000 kbps
Class-map: class-default (match-any)
11971181 packets, 8583659812 bytes
30 second offered rate 10602000 bps, drop rate 0 bps
Match: any
(pkts output/bytes output) 3165/620740
Would you please give me some advice on a proper way to configure reserved bandwidth over the congested tunnel. Attached are running-config file and show policy-map data.
Thanks!
Hugh
18 Replies 18
Joe,
"police" seemed to work for my situation. I was able to keep class low not to exceed 8Mbps. Here the policy-map and show data:
match dscp 2
match dscp 1
policy-map high
class class-default
set dscp 2
policy-map TRAFFIC
class high
bandwidth 2000
class low
police rate 8000000 bps
conform-action transmit
exceed-action drop
policy-map low
class class-default
set dscp 1
Router6-w-AXP#sh policy-map int f2/0
FastEthernet2/0
780244 packets, 561761736 bytes
30 second offered rate 1164000 bps, drop rate 0 bps
Match: dscp 2
30 second rate 1164000 bps
Queueing
bandwidth 2000 kbps
706010 packets, 508024908 bytes
30 second offered rate 9514000 bps, drop rate 1568000 bps
Match: dscp 1
30 second rate 9514000 bps
police:
rate 8000000 bps, burst 250000 bytes, peak-burst 1500 bytes
conformed 631608 packets, 433410268 bytes; actions:
transmit
exceeded 74368 packets, 74611308 bytes; actions:
drop
violated 0 packets, 0 bytes; actions:
drop
drop
conformed 7946000 bps, exceed 1568000 bps, violate 0 bps
323 packets, 58720 bytes
Match: any
(pkts output/bytes output) 231/46268
Router6-w-AXP#
Policier works but shaper doesn't?! What IOS are you running?
Also rather interesting that your one set of stats show 10+ Mbps on an 10 Mbps Ethernet.(?)
"The router wouldn't accept command "set dscp be": "
Just use a value of zero.
I'm running IOS 12.4(24)GC1. I think there's 1024 bits per 1Mb perhaps 10Mbps equal 10240000 bits !!??
I'll try shaper again but I really don't want class low bursts above 8Mbps which shaper usually allows.
I've not worked with that IOS variant. Shaper should also restrict rate, if it doesn't, perhaps an issue within that IOS variant.
