Problem makic RVS4000 VPN router to work.
ruben.hakopian
Just got the RVS4000 vpn router and have some problems making it work. The RVS4000 router is behind another wireless dsl router. I want to achieve the following things:
1) make PCs connected to RVS4000 have an access to internet
2) make PCs connected to RVS4000 access PCs from wireless router network
3) make PCs connected to wireless network access PCs connected to RSV4000 PCs.
I've tried to change the operating mode from Gateway to Router but it does not help. Also addling static entries to routing table does not work out. Please help. In attached image you can see my network topology.
I defined 2 networks 192.168.1.0/255.255.255.0 for wireless router network and 192.168.2.0/255.255.255.0 for RVS4000 network. If its possible to combine these two networks to one it would be better, if not no problem.
Please help making the router work.
Thanks in advance,
Ruben Hakopian.
paolo bevilacqua
Unlikely you will find an answer here on what is not truly a cisco product.
Try Linksys support.
