class map matching question.
Nick Currie
Level 2
Level 2
Hi there I am trying to create a class of traffic for our QOS policy that matches all http and https traffic going to an external endpoint.
 I have applied this config but it doesn't seem to be matching any traffic, I was wondering if someone can point out where I am going wrong.
I have tried to use the match not command to exclude any traffic going to one of our internal private range addresses.
The class map in question is the http2 class shown below, I have included the other classes in case there is a conflict.
Config
class-map match-all doubletake
  description matches doubletake traffic
 match access-group name doubletake_acl
class-map match-all http2
 match not access-group name http_internal_acl
 match access-group name http_acl
class-map match-all abn_mobile
  description matches ABN Mobile traffic
 match access-group name abn_mobile_acl
class-map match-all MS_File
  description Microsoft CIFS protocol
 match access-group name ms_file_acl
policy-map QOS
 class MS_File
  shape average 10240000
 class doubletake
 class abn_mobile
  shape average 4000000
 class http2
  shape average 20000000
interface GigabitEthernet0/0/1
 description AMCOM
 bandwidth 50000
 ip address x.x.x.x
 ip flow monitor Flow_Mon input
 speed 100
 no negotiation auto
 service-policy output QOS
ip access-list extended abn_mobile_acl
 permit ip 192.168.68.0 0.0.0.255 any
 permit tcp 192.168.68.0 0.0.0.255 any
 permit udp 192.168.68.0 0.0.0.255 any
ip access-list extended doubletake_acl
 permit tcp any any eq 6320
 permit tcp any host 192.168.12.20
ip access-list extended http_acl
 permit tcp any eq www any time-range Production_Hours
 permit tcp any eq 443 any time-range Production_Hours
ip access-list extended http_internal_acl
 permit tcp any 192.168.0.0 0.0.255.255
 permit tcp any 10.0.0.0 0.255.255.255
 permit tcp any 172.30.0.0 0.0.255.255
 periodic weekdays 6:00 to 18:00
When I check to see if the class map is matching any traffic I get 0 packets matched:
DAC_WAN1_4321#show policy-map interface gi0/0/1 output class http2
  Service-policy output: QOS
    Class-map: http2 (match-all)
      0 packets, 0 bytes
      5 minute offered rate 0000 bps, drop rate 0000 bps
      Match: not access-group name http_internal_acl
      Match: access-group name http_acl
      Queueing
      queue limit 83 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 0/0
      shape (average) cir 20000000, bc 80000, be 80000
      target shape rate 20000000
Philip D'Ath
Meraki Community All-Star
I can't see anything wrong with that, but perhaps try creating a single access list and match on that.
ip access-list extended http_internal_acl_v2
 deny ip any 192.168.0.0 0.0.255.255
 deny ip any 10.0.0.0 0.255.255.255
 deny ip any 172.30.0.0 0.0.255.255
11 Replies 11
Philip D'Ath
What kind of Cisco model of Cisco device is this being done on, and what software version are you running?
With the http traffic, are you concerned about limiting it coming into your site (aka typical web browsing) or going out of your site (aka like a web server)?  If you are worried about it coming in then note you need to shape the traffic as it heads towards the inside of the network (such as an internal VLAN interface), rather than on the Internet facing interface.
Hi Phillip - this is on a 4321 router. I know the feature works as there are other shape average policies which are matching traffic.
software version: Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(2)S, RELEASE SOFTWARE (fc3)
Its outbound web traffic, this is a remote site WAN router, I want to shape the internet bound traffic without affecting any web traffic to internal services.
Philip D'Ath
The class has two match criteria and bot have to be true for it to work.
To isolate the issue down, try only using one match at a time.  For example, if you just use " match not access-group name http_internal_acl" does it start getting hits.  If you just use " match access-group name http_acl" does it start getting hits.
I'm guessing one of them wont.  Once we understand which one is not working we can try and figure out why.
Thanks Phil,
I was running the rule as a single ACL match previously just using  match access-group name http_acl.  There were no issues with that, however I wanted to exclude internal http and https traffic which is why I added the match not access-group name http_internal_acl condition. Can you see anything wrong with that statement?
I didn't bother with the port on the ACL for matching traffic as I didn't think it was needed.
Philip D'Ath
Ahh ok thanks Phillip, I wasn't aware that I could exclude any traffic to 192.168.0.0 255.255.0.0 by just including a deny statement at the start of the ACL. I assume the deny has to come before the permit?
Philip D'Ath
That is correct.
Hi Nick,
If the traffic is destined to external HTTP servers and the direction is outbound can you verify the below mentioned ACL--
The ports mentioned here are source ports but they should be destination ports since the client will be trying to open a specific port on the external servers in this case HTTP and HTTPS and not use these reserved port numbers as source ports.
Can you change this and check--
permit tcp any any eq www time-range Production_Hours
permit tcp any any eq 443 time-range Production_Hours
This is the start, if this doesn't help please revert and we'll try to sift through the config again.
Shaunak
Hi Shaunak, thanks for your reply!
I spotted this too and changed the acl to this:
It is actually working properly, i tested with iperf3 to see the effects of the shaping. However seeing as its web traffic the traffic flow is heavily weighted to incoming rather than outgoing. I have applied the relevant config to our inbound routers and have achieved shaping heaven, thank you for your help guys!!!
Philip D'Ath
Just looking at this further, does the ms_file_acl exist?  That is the first match criteria.
abn_mobile is the third match criteria, and it matches:
Could this class be catching the test traffic?  If does overlap with your internal class - but will be tested first because it is higher up.
Hi Phil
Yes sorry the ms_file ACL was missed out on that post, but its there.
ip access-list extended ms_file_acl
 permit tcp any eq 445 any time-range Production_Hours
192.168.68.0/24 network is not part of this traffic, that network is to be shaped to 4 mb.
