My GRE tunnel doesnt comming up
kamankolie
hello all i have an issue on my gre tunnel configuration, can some  one help me too solve this please.
see below the config file:
interface Tunnel60030
 description Tunnel STUB
 bandwidth 2048
 ip address 172.24.XX.XX 255.255.255.252
 ip mtu 1400
 ip flow ingress
 ip flow egress
 ip tcp adjust-mss 1300
 keepalive 10 3
 tunnel source 192.168.XX.17
 tunnel destination 192.168.XX.19
interface Tunnel60040
 description Tunnel to Kaloum(wimax)
 ip mtu 1400
 ip flow ingress
 ip flow egress
 keepalive 10 3
 tunnel source 192.168.XX.19
 tunnel destination 192.168.XX.17
brianw2
Are the tunnel source and destination addresses in the same subnet?
5 Replies 5
brianw2
YES. WITH mask 255.255.255.240
I would like to do gather more information about your setup so I can troubleshoot. What type of devices are you using? Can you provide me with the running config for the devices that this tunnel is setup on?
site 1 config:
interface Loopback0
 ip address 172.16.154.4 255.255.255.255
interface Tunnel60045
 description Tunnel to Kaloum(fiber)
 ip address 172.24.90.30 255.255.255.252
 keepalive 10 3
 tunnel source 192.168.10.20
 tunnel destination 192.168.10.33
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description CONNECTION TO SWITCH
 ip address 10.78.12.1 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 192.168.10.20 255.255.255.240
 duplex auto
 speed auto
router eigrp 20
 network 10.78.12.0 0.0.0.255
 network 172.16.154.4 0.0.0.0
 network 172.24.90.57 0.0.0.0
 passive-interface default
 no passive-interface GigabitEthernet0/0
 no passive-interface Tunnel60040
hello ...
Dear i would like to do gather more information site2  also here in site 1 seem mtu command is missing.
let me know both site mtu is default or  manualy configure ??
