Class of Service vs. Quality of Service
Hello group,
We are in the beginning of a major network upgrade. We currently run network services on a NetVPN (ATT) network and are migrating to AVPN. As we move forward, we're going to be building in Class of Service based on available configurations. We currently use QoS to mange traffic on our routers. (I'm a bit new with some of this stuff, so pardon me if I mangle terms.) I am doing some research, but when you don't know, what you don't know..... So, I'm wondering if we'll need to 'blow away' our current configuration to accomodate the new CoS? Here's a code snippet of our current configuration:
Class map and policy map:
class-map match-any Business_Ingress
match access-group 130
class-map match-any Business_Data
match ip dscp af21
class-map match-any ATM_Traffic
match access-group 140
class-map match-any Voice
match  dscp ef
match access-group name Voice-Traffic
class-map match-any Replication
match access-group 150
class-map match-any Voice_Ingress
policy-map Voice-Traffic
class Voice
  priority percent 15
class Business_Data
  bandwidth percent 64
class Replication
    police 7000000
class ATM_Traffic
  priority percent 5
class class-default
policy-map WAN_QOS
class class-default
  shape average 10000000
  service-policy Voice-Traffic
policy-map QOS_INGRESS_LAN
class Business_Ingress
  set ip dscp af21
class Voice_Ingress
  set ip dscp ef
ACCESS LISTS:
access-list 5 permit 0.0.0.0
access-list 6 permit 208.61.216.1
access-list 7 permit 10.15.1.0 0.0.0.255
access-list 10 permit 0.0.0.0
access-list 10 permit any
access-list 20 permit 10.20.102.22
access-list 100 permit ip 10.20.102.0 0.0.0.255 any
access-list 100 deny   ip any 170.209.0.2 0.0.0.1
access-list 100 permit ip any any
access-list 120 deny   ip host 10.20.102.22 any
access-list 120 permit ip host 10.20.102.89 any
access-list 120 deny   ip any any
access-list 127 deny   ip host 10.20.102.51 host 205.152.226.254
access-list 127 deny   ip host 10.20.102.51 host 205.152.0.5
access-list 127 permit ip host 10.20.102.51 any
access-list 127 deny   ip host 10.20.102.52 host 205.152.226.254
access-list 127 deny   ip host 10.20.102.52 host 205.152.0.5
access-list 127 permit ip host 10.20.102.52 any
access-list 127 deny   ip any any
access-list 130 deny   ip 10.20.100.0 0.0.0.255 any
access-list 130 deny   ip host 10.20.102.8 any
access-list 130 deny   ip host 10.20.102.154 any
access-list 130 deny   ip host 10.20.102.23 any
access-list 130 permit ip 10.20.0.0 0.0.255.255 10.20.0.0 0.0.255.255
access-list 140 permit ip any host 10.20.105.254
access-list 140 permit ip any host 10.20.110.254
access-list 140 permit ip any host 10.20.112.254
access-list 140 permit ip any host 10.20.114.254
access-list 140 permit ip any host 10.20.117.2
access-list 140 permit ip any host 10.20.118.254
access-list 140 permit ip any host 10.20.122.254
access-list 140 permit ip any host 10.20.124.254
access-list 140 permit ip any host 10.20.128.254
access-list 140 permit ip any host 10.20.126.254
access-list 140 permit ip any host 10.20.134.254
access-list 140 permit ip any host 10.20.132.254
access-list 140 permit ip any host 10.20.140.254
access-list 140 permit ip any host 10.20.142.254
access-list 150 permit ip 10.20.100.0 0.0.0.255 any
access-list 150 permit ip host 10.20.102.8 any
access-list 150 permit ip host 10.20.102.23 any
access-list 150 permit ip host 10.20.102.154 any
If someone could direct me to some information for further reading, I'd appreciate it.
Chris
what is you IOS version..
you may refer this document....
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfmcli2.html
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfcbmrk.html#wp1005766
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
Jeff Van Houten
Level 5
Level 5
If you are talking about outbound QOS pointed toward the wan, the first thing you need to do is understand what the wan provider will accept. You can come up with a very finely detailed 13 cos breakdown of all your traffic, but if the wan provider is only going to accept 5 classes, it doesn't really matter. Find out what Avpn will accept and tune your markings to those.
The next thing I would personally recommend is to keep it simple. Start with voice, then add mission critical business, then maybe video, then everything else. Start with a simple policy, mark the outbound to what the provider will accept, set priority queue for voice, insure your mission critical has a large enough reservation and you'll likely have 90% of your problem solved.
