Clear IP DHCP Bind
namlhitn
Hi, i config DHCP server on Switch CBS350, i have a network pool 192.168.10.0/23 and setup lease time 1 day. But i see it isn't release IP, Is it setting IP according to mac address? I want an IP address that can be set for multiple devices, because if I don't do that, I won't have any IP left to assign to new devices.
7 Replies 7
DanielP211
If you setup the lease to 1 day, and the computer is not available on the network after one day the lease will expire and the IP will be free to reuse.
BR
****Kindly rate all useful posts*****
I have installed 1 hour, but the IP expire is not reuse for new devices
It round Robin' it will assign IP until it returns again to this IP.
You can make sure by config only one IP in dhcp pool and check if ip is reuse or not.
round robin means, for example, I create network pool 192.168.0.1-254, for example ip 192.168.1.10 is expiring, if there is a new device requesting IP, DHCP will grant in the range 192.168.0.11-254, If there are no more IP addresses in that IP address range, 192.168.1.10 will be allocated, right?
Correct
Make sure the PC is not on the network anymore. You can also check the leases and you will see that the leases are empty.
Nope, it's show expire with old mac address
