Routing Between GETVPN and normal Tunnel interface
SherifDiab
Hello All,
I have a setup where all the Cisco routers are using GETVPN configuration.
Now I need to connect my SDWAN appliance to one of these Cisco routers but it only support normal IPsec tunneling on Tunnel interface.
Is there a way to include the Tunnel interface in routing with the GETVPN Tunnel-less set up?
the traffic flow should be as follows
LAN  -> SDWAN Edge -> IPsec tunnel -> Cisco router Tunnel interface -> GETVPN -> destination
Assum my LAN IP : 10.5.0.0/16
destination : 172.20.20.20
Praveen Anand
Hi Sherif,
GETVPN/ GETVPN configuration is not  supported on IOS-XE SDWAN. however to answer your traffic flow questions,
it would be a SDWAN ROUTER =========IPSEC Tunnel =======GETVPN ROUTER ======GETVPN MESH.
you can route traffic with static routes. From Cedge perspective, it is just traffic being forwarded to the IPsec tunnel.
- Praveen Anand
