CLI command
Nomaan
Community Member
  • I am learning cisco now, I have seen that our mentor go enable to privileged mode by one click not typing command how he do that??
Martin L
It is privilege level where 15 is the highest, and goes straight to config mode, aka privileged mode, u can add privilege level into username or add separate under console or/and telnet lines
username martin privilege 15 password cisco that is command; go to CLI, enable, config t, then add that command. then add following:
! to use console cable
line con 0
login local
privilege level 15
! to use telnet
line vty 0 4
password C1sc0
login
! or use login local which ask for above martin's password
privilege level 15
Regards, ML
**Please Rate All Helpful Responses **
DanielP211
He probably used a user with privilege 15. So just add privilege level to you user.
BR
****Kindly rate all useful posts*****
Joseph W. Doherty
Since you're learning Cisco, just want to mention there's NO privileged MODE but there are 16 (?) privilege LEVELS.  The ENABLE command allows you to select a privilege level.
