client to vpn
support.golan
hello
i am useing cisco 1841
i want to create client vpn to my cisco 1841 route
can you please send me instructions and how can i check if my router version support client vpn
golan
Richard Burts
Golan
To support VPN your 1841 should be running a feature set such as Advanced Security or Advanced IP Services. What feature set is your 1841 running?  If you are not sure you might post the output of show version and we can tell you.
Or you can tell directly whether your router supports VPN by attempting to configure a VPN feature. You might try something like:
crypto isakmp policy 10
or:
crypto map testmap 10 ipsec-isakmp
If either of these are accepted then your 1841 will support VPN. If the 1841 responds with invalid input then your 1841 is running a feature set that does not support VPN and you will need to upgrade your feature set to be able to do VPN.
Rick
Rick
does it support client vpn?
FIRST ROUTER :
London#show version
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(3i), RELEASE SO                            FTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 28-Nov-07 18:17 by stshen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
London-TT uptime is 7 weeks, 5 days, 16 hours, 18 minutes
System image file is "flash:c1841-ipbase-mz.124-3i.bin"
Cisco 1841 (revision 7.0) with 114688K/16384K bytes of memory.
Processor board ID FCZ130214L1
6 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
SECOND ROUTER:
Frankfurt#show version
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 13-Aug-08 15:34 by prod_rel_team
MplsFrankfurt uptime is 3 days, 2 hours, 58 minutes
System image file is "flash:c1841-ipbase-mz.124-15.T7.bin"
Cisco 1841 (revision 7.0) with 115712K/15360K bytes of memory.
Processor board ID FCZ132212GW
31808K bytes of ATA CompactFlash (Read/Write)
Golan
Both of these routers are running the IP BASE feature set and this feature set does not support VPN. To be able to support VPN you would need to upgrade the feature set on at least one of these routers.
Rick
Rick
