Clients unable to browse the internet on Cisco 871 K9 Router
tosino489
Hi Everyone,
i just purchased my Cisco Router 871 K9 Version running this System image flash:c870-advsecurityk9-mz.124-4.T8.bin"
I am trying to configure this Router for Home use so that i can block some Web traffic (Porn sites, Movie sites because of Children) but i realised i was unable to apply the Access list Match-class version url (http host).
My major problem is even the basic config on the router. The WAN has a DHCP IP assignment with Network 192.168.1.0
The Lan is expected to have 192.168.3.0 Network. The IPs appears to be correctly assigned but not able to ping the internet on the Router. Local client also cannot resolve DNS. here is my cofig file.
Please assist.
Richard#sh run
Building configuration...
Current configuration : 1727 bytes
version 12.4
no service pad
hostname Richard
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp pool Richard-Pool
import all
network 192.168.3.0 255.255.255.0
default-router 192.168.3.1
domain-name richardedet.com
dns-server 192.168.1.1
lease 0 2
interface FastEthernet0
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address dhcp
ip verify unicast source reachable-via rx allow-default 100
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
speed auto
full-duplex
interface Vlan1
description Local Network VLAN
ip address 192.168.3.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip route 192.168.3.0 255.255.255.0 FastEthernet4
no ip http server
no ip http secure-server
ip nat inside source list 101 interface FastEthernet4 overload
ip nat inside source route-map RMAP-NAT interface FastEthernet4 overload
ip dns server
logging trap debugging
logging facility local2
access-list 100 permit udp any any eq bootpc
access-list 100 permit tcp any any
access-list 100 permit icmp any any
access-list 101 permit ip 192.168.3.0 0.0.0.255 any
control-plane
line con 0
password richard
login
no modem enable
transport output telnet
line aux 0
password richard
login
line vty 0 3
password richard
login
transport input ssh
line vty 4
password richard
login
scheduler max-task-time 5000
end
15 Replies 15
Fastethernet 0-3 are switchport. You should not have any problem. Can you check the IP addresses and sunbet masks configured on two of PCs. They can not ping eachother? Do you have any firewall or anti virus installed on the PCs. Try to turn windows firewall off .
Masoud
