Clock Settings for E3 controller
mpsameer
hi All,
This is very urgent.
What should be the clock settings for E3 controller which is at Provider Edge (PE)and clock settings for E3 which is at Customer edge (CE).
kindly reply at the earliest.
Sam
gauravprakash
Normally your service providers shud provide clock. Just try providing the clock on CE , if it works good, else remove it ..
Also can u let us know which card are you using..?
Thx,
G
Dear G,
I wanted to know what clock settings should be set on PE and CE side? like clock source should be line or internal on e3 controllers...
Sam
Sam,
clock rate usually provided by Service Provider so try to have clock source line on both side.
