%ESWMOD-4-QUEUE_FULL:
enriquebs
HI all,
Here is an output of the "sh log" command:
Sep 26 01:55:24: %ESWMOD-4-QUEUE_FULL: Ethernet Switch Module transmit queue is full
Sep 26 01:55:42: %ESWMOD-4-QUEUE_FULL: Ethernet Switch Module transmit queue is full
Sep 26 01:56:24: %ESWMOD-4-QUEUE_FULL: Ethernet Switch Module transmit queue is full
Sep 26 01:57:24: %ESWMOD-4-QUEUE_FULL: Ethernet Switch Module transmit queue is full
The log buffer is full of this errors and the "sh inter fasX" don't shows any drop or something like that... has anyone deals with an issue like that?
Thx a lot in advance.
cheers,
spremkumar
Level 9
Level 9
hope this helps..
%ESWMOD-4-QUEUE_FULL : Ethernet Switch Module transmit queue is full\n
Explanation The transmit queue for the switch module is full and packets are being dropped.
Recommended Action Reduce the rate of packet transmission to the switched virtual interfaces to be lower than 9 Mbps.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_system_message_guide_chapter09186a0080228ef9.html#wp804152
regds
Thx for the response, so... I don't understand why this error if there are no drops in the interface counters...
