Clocking and Slip secs on T1s
joel
I have a 2811 with one VWIC2-2MFT-T1/E1, one port has a data MPLS circuit and the other has a Voice PRI. I am running c2800nm-advipservicesk9-mz.124-11.XW5.bin
My PRI does not get slips but my MPLS does. How do I utilize the independant clocking for each port.
I have a few quesions from this link
http://cisco.com/en/US/products/hw/modules/ps2617/products_configuration_example09186a008052c920.shtml
Enhanced clocking capabilities--The 2-port MFT VWIC2s can enable each port to be clocked from independent clock sources for data applications. This independent clocking capability is """not supported for voice applications""" and not supported with the AIM-ATM-VOICE-30 module.
DOES THIS MEAN IT IS NOT SUPPORTED FOR VOICE PRIs?
Cisco IOS Image -- To run these features on T1/E1 interfaces, you must install an IP Plus or IP Voice image (minimum) of Cisco IOS Release 12.3(14)T or a later release.
DO I HAVE TO BE IN THE 12.X T, I'M USING XW TRAIN?
* Independent Clocking Mode -- The independent clocking mode is supported only on these modules:
o VWIC2-1MFT-G703
o VWIC2-2MFT-G703
o VWIC2-2MFT-T1/E1
o VWIC2-1MFT-T1/E1
To enable independent clocking mode, use the keyword independent in the clock source command.
I DO NOT SEE INDEPENDANT AS AN OPTION IN THIS ROUTER, IS THIS BECAUSE OF THE WRONG IOS?
2811(config-controller)#clock source ?
free-running Free Running Clock
internal Internal Clock
line Recovered Clock
MY CURRENT CONFIG
network-clock-participate wic 0
network-clock-select 1 T1 0/0/1
network-clock-select 2 T1 0/0/0
controller T1 0/0/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
description QwestPRN
controller T1 0/0/1
framing esf
linecode b8zs
pri-group timeslots 1-10,24
HELP HELP HELP!!!
joel
paolo bevilacqua
Already replied in another thread.
