Closing Ports 2001,4001,6001 and 9001
TRACY HARTMANN
Our security department wants me to close tcp ports 2001,4001,6001 and 9001.  Below is part of my configuration
Interface Fastethernet0/0
IP address X.X.X.x
ip access-group control out
ip access-list extended control
deny tcp any any eq 2001
deny tcp any any eq 4001
deny tcp any any eq 6001
deny tcp any any eq 9001
permit any any
When they do a scan outside the company network is still shows up open.  I have tried both a ip access-group in and out and it never seems to hit the ACL.  The scan being done is on the f0/0 ip address.
19 Replies 19
ehh, I'd say you're trying to put the ACL on wrong interface, your Outside, or WAN interface is seemed to be s0/0/0:
interface s0/0/0
ip address 8.9.10.11 X.x.x.x
encapsulation PPP
try to put acl "pci" as inbound onto that interface.
Yep that was the problem, as soon as I added the ACL to the Serial it worked.  Is that because when the traffic comes into the Serial it passes the traffic to the Ethernet via the backplane?
exactly, if one try to reach the IP address assigned to the LAN interface and the traffic comes in via WAN interface, then ACL, which are applied to the LAN interface will be not processed.
rn.becker
Tracy, I've run into the same thing you are (although I know this is two years after the fact).  I discovered here that the ports we're talking about are related to telnet streams on rotary ports.
Table: TCP Port Telnet Access to Cisco Products (Earlier Releases)
TCP Port Number Access Method
7
Echo
9
Discard
23
Telnet (to virtual terminal VTY ports in rotary fashion)
79
Finger
1993
SNMP over TCP
2001 through 2999
Telnet to auxiliary (AUX) port, terminal (TTY) ports, and virtual terminal (VTY) ports
3001 through 3999
Telnet to rotary ports (access via these ports is only possible if the rotaries have been explicitly configured first with the rotary command)
4001 through 4999
Telnet (stream mode) mirror of 2000 range
5001 through 5999
Telnet (stream mode) mirror of 3000 range (access via these ports is possible only if the rotaries have been explicitly configured first)
6001 through 6999
Telnet (binary mode) mirror of 2000 range
7001 through 7999
Telnet (binary mode) mirror of 3000 range (access via these ports is possible only if the rotaries have been explicitly configured first)
8001 through 8999
Xremote (communication servers only)
9001 through 9999
Reverse Xremote (communication servers only)
10001 through 19999
Reverse Xremote rotary (communication servers only; access via these ports is possible only if the ports have been explicitly configured first)
Digging a little deeper, I discovered that the AUX port on a router is available via TCP.  At the router, execute
     router#show line
In my case on a Cisco 2501 I got:
router#show line
   Tty Typ     Tx/Rx    A Modem  Roty AccO AccI   Uses   Noise  Overruns   Int
*    0 CTY              -    -      -    -    -      2       0     0/0       -
     1 AUX   9600/9600  -    -      -    -    -     15       0     0/0       -
     2 VTY              -    -      -    -    -     35       0     0/0       -
     3 VTY              -    -      -    -    -      2       0     0/0       -
     4 VTY              -    -      -    -    -      0       0     0/0       -
     5 VTY              -    -      -    -    -      0       0     0/0       -
     6 VTY              -    -      -    -    -      0       0     0/0       -
More digging around about configuring AUX ports found this article.  It describes how to configure and access the AUX ports via a telnet session.  Basically, you start at 2000, 4000, 6000, or 9000, and then add the line number for the AUX port.  As you can see above, the line number for my AUX port is 1, so if I want to telnet to that port, I would use
router>telnet 10.100.0.254 2001 or 4001 or 6001 or 9001
AUX ports start at AUX 0 and by default these ports are on, even though there may not be anything about them in the configuration.  To turn the AUX port off, you do it the same way as you do with a VTY line.
router#conf t
router(config)#line aux 0
router(config-line)#transport input none
end
copy run start
Thanks Dude..
