Cluster chain broken on file
yeskriya007
I tried upgrading my GSR's IOS. while i was half way through the download of the IOS, i had accidently terminated the file copy by closing the tftp server. In the 'show disk0:' command the file which i was trying to copy is shown with a file length of 5455872 bytes. To upload the file again i tried deleting the existing half copied IOS. But i get the following message "%Error deleting disk0:c12kprp-p-mz.120-32.S4.bin (Cluster chain broken on file)"
I could not squeeze the disk also.
The show version, disk0 of the router are given below:
Router#sh disk0:
-#- --length-- -----date/time------ path
1 5455872 Jan 12 2007 22:49:32 c12kprp-p-mz.120-32.S4.bin
2 18220064 Jan 14 2007 00:07:02 c12kprp-k3p-mz.120-25.S1.bin
3 26308840 Jan 14 2007 00:42:30 c12kprp-p-mz.120-32.S44.bin
13959168 bytes available (49938432 bytes used)
Router#delete disk0:c12kprp-p-mz.120-32.S4.bin
Delete filename [c12kprp-p-mz.120-32.S4.bin]?
Delete disk0:c12kprp-p-mz.120-32.S4.bin? [confirm]
Router#sh ver
IOS (tm) GS Software (C12KPRP-K3P-M), Version 12.0(25)S1, EARLY DEPLOYMENT RELEA
SE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Thu 03-Jul-03 05:43 by nmasa
Image text-base: 0x00010000, data-base: 0x0325A000
ROM: System Bootstrap, Version 12.0(20030502:164925) [spalleti-24S 1.6dev(0.1)]
DEVELOPMENT SOFTWARE
BOOTLDR: GS Software (C12KPRP-K3P-M), Version 12.0(25)S1, EARLY DEPLOYMENT RELEA
SE SOFTWARE (fc1)
Router uptime is 33 weeks, 5 days, 16 hours, 53 minutes
System returned to ROM by reload
System restarted at 16:20:14 IST Mon May 22 2006
System image file is "disk0:c12kprp-k3p-mz.120-25.S1.bin"
cisco 12410/PRP (MPC7450) processor (revision 0x00) with 524288K bytes of memory
MPC7450 CPU at 665Mhz, Rev 2.1, 256KB L2, 2048KB L3 Cache
Last reset from power-on
2 Route Processor Cards
2 Clock Scheduler Cards
5 Switch Fabric Cards
2 8-port OC3 POS controllers (16 POS).
1 four-port OC12 POS controller (4 POS).
1 twelve-port DS3 controller (12 DS3).
2 Four Port Gigabit Ethernet/IEEE 802.3z controllers (8 GigabitEthernet).
4 OC12 channelized to STS-12c/STM-4, STS-3c/STM-1 or DS-3/E3 controllers
2 Ethernet/IEEE 802.3 interface(s)
8 GigabitEthernet/IEEE 802.3 interface(s)
7 Serial network interface(s)
27 Packet over SONET network interface(s)
2043K bytes of non-volatile configuration memory.
62720K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 256K).
Currently as a workaround i had copied the IOS into the bootflash. Kinldy suggest how i would be able to delete this file from disk0:
thanks in advance,
Karthi.
apaxson
What does it say, if you attempted to tftp the file again, and overwrite the previous one?
Hi Apaxson,
Tried uploading again via tftp and disk-disk copy. I am getting the same error message.
Router#copy stby-disk0:c12kprp-p-mz.120-32.S4.bin disk0:
Destination filename [c12kprp-p-mz.120-32.S4.bin]?
%Warning:There is a file already existing with this name
Do you want to over write? [confirm]
%Error opening disk0:c12kprp-p-mz.120-32.S4.bin (Cluster chain broken on file)
So i have removed the disk and inserted into my laptop and deleted the half-copied file.
Thanks.
