Ospf issue
acbenny
Hi expert,
What is the maximum ospf node in a ospf network ?
How to calculate the cost of the ospf link ? As I know, it is calculated base on the bandwidth, is it right ? any formula ?
Thanks !
dan.cicioiu
cost = 10^8/ bandwidth value = 100,000,000 / bandwidth value
you can set the bandwidth of the interface , or u can set the cost of the interface :
Router(config)#interface s0
Router(config-if)#ip ospf cost 100
or
Router(config)#interface s1
Router(config-if)#bandwidth 56
the number of nodes i think must be less then 1000 .
