cofiguring an ethernet interface
nammoussa
I have a cisco 1700 Router with one ethernet interface and two serial wan.
the first wan is used to connect two distant agencies. Now i want to connect to another companie over the second wan, but this company askes me to use different IP adressing. But i have only one ethernet interface.Can you tel me which solution is better?
And if i can use two different sub-ethernet interfaces?
Thank you !!!
amit-singh
Level 8
Level 8
If you dont have another ethernet port you can do it using 2 ways :
1. Define a secondry IP on the ethernet interface for your second subnet.
2. Define the trunk between the switch and the router interface and create the sub-interfaces.
Use PBR to effictively route the traffic between your different customers otherwise your LAN users will be able to access the other customers.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt1/qcfpbr.htm
HTH,
-amit singh
