Collecting core dump on CISCO 4451 router - TFTP timing out
stork
I'm trying to copy a core dump from my Cisco 4451 router, but it keeps timing out when the file is almost done being transferred.
> copy bootflash:/core/<core dumbe> tftp: < server IP>
> timeout error occurs once the file is almost complete.
Is there something that can be done to prevent this or is the file just too big and I need to get someone to console in and copy to a usb device or something?
not sure which TFTP server software you are using, but try the Solarwinds server, maybe it is the software that causes your problem...
https://www.solarwinds.com/free-tools/free-tftp-server
7 Replies 7
Leo Laohoo
Archive the files in the coredump folder and then export it out.
I don't suppose you could point me in the right direction of some documents for doing this on the router.
archive tar /create <FILENAME>.tar bootflash:/core
All this did was may a bigger file, which is the issue I believe.
Well Solarwinds worked!  I was using 3CDaemon.  Was going to try the blocksize next but didn't need to this time.
you could try and change the TFTP blocksize. Try different values...
4451(config)#ip tftp blocksize
