This is a common mistake with 837s- they are actually full-duplex capable.
The 'ethernet' port is actually a virtual port which is kind of software-bridged to the four physical fastethernet ports.
So you can't set the duplex on the ethernet port, but you can on whichever fastethernet port you have the cable connected to.
Set that to 10 full or 100 full, set your 1760 to match, and that will sort out your port errors.
Unfortunately there is what I'd call a bug, but Cisco would probably call 'by design' where CDP will keep telling you that there is a duplex mismatch.
You can either ignore it or disable CDP on the port.
You'll be able to verify the config by looking at the error/crc/collision counters on the ports ( the fastethernet1/2/3/4 physical port and the 1760 port being the important ones).
Aaron
Please rate helpful posts...
Aaron
Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
