collision pro
rbforever25
HELLO FRIEND
I have cisco 2522 router, it is directly connected to a cisco 1900 switch. While telnet to 2522 router it gives very slow response.
Hi there,
As far as i can say, the problem in such cases is always related to either Duplex mismatch, cabling problems or high CPU utilization on the router.
HTH,
Mohammed Mahmoud.
5 Replies 5
mohammedmahmoud
Level 11
Level 11
Hi there,
Kindly check the speed/duplex on both sides.
HTH, please rate if it does help,
Mohammed Mahmoud.
hi
thanks
but we had allready tried that, it reduced late collision, but no change in its access speed.
Hi there,
HTH,
Mohammed Mahmoud.
hi thanks budy
nice to meet u
ok
bye
Hi Bhavin,
You are welcomed :)
BR,
Mohammed Mahmoud.
