RIP protocol
alwahidi22
Thank you all for your information ...
i have this network topology and configured using RIP v1 in my virtual lab ...
192.168.1.32/27---R1----10.1.1.0/24-----R2------192.168.1.64/27
by default it shouldn't work using RIP v1 but it works well..we have different subnet masks....
so why it works....
12 Replies 12
mohammedmahmoud
Level 11
Level 11
Hi there,
This is called discontigous network, normally R1 should advertise 192.168.1.0 (auto-summary), and R2 will drop the route since it has learned a subnet of the same major network from a connected interface, please issue a debug ip rip to trace the operation.
Please refer to these documents:
Behavior of RIP and IGRP When Sending and Receiving Updates
http://www.cisco.com/en/US/tech/tk364/technologies_tech_note09186a0080093fd8.shtml
Why Doesn't RIP or IGRP Support Discontiguous Networks?
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080093fd6.shtml
HTH, please rate if it does help,
Mohammed Mahmoud.
thank you Mohammed for your response , but 1) i want to know that i can use different subnet mask lengths within RIP networks , if yes why we say that RIP is clasfull protocol
2) discontigous network you mean here that we connect for example two networks(class A) for example using network( class B ) or using different network portion ( class A )
You can use different subnet masks per major subnet ie. you could use the following
10.5.1.0/24
10.5.2.0/24
192.168.1.0/28
192.168.1.16/28
etc...
You cannot use different subnets within the same major network ie.
192.168.1.0/28
192.168.1.128/25
This is because RIP does not exhange the subnet mask in it's routing updates.
Discontiguous means exactly what you say and what you have done in your lab.
Jon
thank you jon
i appreciated your response and it was very helpful for me , so 1)the discontiguous network doesn't work with RIP ?
...2)is the following topology Discontiguous network ?
3)is the following topology work with RIP v1?
192.168.1.0/24---R1---192.168.4.4/30----R2----192.168.2.0/24
by the way this is one of the topology that used in one of cisco books
No this is not a discontiguous example.
The major network numbers are
192.168.1.0/24
192.168.4.0/24
192.168.2.0/24
So you do not have a major network that is split by another major network.
Yes the above topology should work with RIPv1 for the reasons stated above.
Jon
Hi there,
You're last example is not a discontigous network (no major network overlap), but your original post was a discontigous network, and RIPv1 doesn't support discontigous networks, as it never sends the subnet mask with the routes, please refer to the documents i've send you.
HTH,
Mohammed Mahmoud.
192.168.1.32/27-----R1-----192.168.4.4/30----R2-----192.168.1.64/27
does this topology work with RIP V1
No it shouldn't because here you do have a discontiguous major network ie. 192.168.1.0.
See Mohmammed's links for more details.
Jon
Just as Jon has said, it shouldn't work as its a discontigous network, and referring to the link both routers will drop the routes exchanged since they match the major boundary.
HTH,
Mohammed Mahmoud.
Thank you Mohammad , i appreciated your ideas and i hope to be friends
Hi Ibrahim,
You are always welcomed, and i'll be glade to have you as a friend.
BR,
Mohammed Mahmoud.
Thank you jon , i have understand all the ideas you talk
thank you very much
