Combine Frame relay Interfaces
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-14-2007 08:55 AM - edited 03-03-2019 07:33 PM
Guys,
i have a request from a customer and am not too sure how to go about it. they currently have a frame-relay point-to-point network. now head office is going to increase their bandwidth so the provider told them to do the following
1. add a second serial card on their router
2. provider brings in another frame-link.
3. router is configured to aggregate both links as one.
my question is simple (i hope). how can this be done? ive seen docs on PPP but thats different from this.
The current Routing Protocol is EIGRP.
Any suggestions would defintely be appreciated.
thanks in advance
- Labels:
WAN
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-14-2007 09:14 AM
look like the SP will provision this as multilink Frame Relay (FRF.16) to give you a virtual interface that bundles the two physical ones. The router supports this:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00804554eb.html
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-14-2007 09:29 AM
thanks,
i just got the request and have not done this before. the router is a 2600 with IOS 12.2 ( i think- awaitng the tech-suport to confirm). i told them that if that is the case, the router stability may be a serious factor to consider and have recommended a router upgrade. advised that CPU load may also increase and may cause other issues.
They have already placed a second WAN card on the router.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-14-2007 10:41 AM
Hi, FRF.16 is supported from 12.2(8)T and onward. Any latest maintenance release is supposed to work fine on the 2600 and not increase the load much.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-14-2007 11:52 AM
so one final question though. reading through the doc i get the jist of it. but say i currently have 32 remote branches. im seeing that i now create MFR sub interfaces. do i change and configurations on the remote side? DLCI , IP addressing etc?
whats the basic config
1. head office - create the bundle
2. branch office - ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-14-2007 12:49 PM
No changes whatsoever are needed in IP addressing neither for the DLCI numbers, but confirm this latest point with SP.
No configuration changes are necessary at the branch.
Thanks for the nice rating and good luck!
