Combine police with bandwidth in policy-map
billmatthews
We have an outbound QOS policy applied to a serial T1.  We have a priority reservation for voice.  For some of the remaining classes we use bandwidth remaining statements.
policy-map qosoutbound
class TAG-EF
  set dscp ef
  priority 480
class TAG-AF41
  set dscp af41
class TAG-AF42
  set dscp af42
  bandwidth remaining percent 10
class TAG-AF31
  set dscp af31
  bandwidth remaining percent 15
class TAG-AF21
  set dscp af21
  bandwidth remaining percent 25
class TAG-AF11
  set dscp af11
.....etc....
However for one class (tag-af21) we want to enforce a bandwidth limit.   Can I combine a police cir with the bandwidth statements?
class TAG-AF21
  set dscp af21
  police cir 768000
   conform-action transmit
   exceed-action drop
Bill
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Yes you can police.  You consider shaping instead.  Or if you police, instead of dropping packet you might mark it down.
Hello
Even though the ios excepts the policer with the bw% I am curious how qos would read the policy?
Another option would to apply the policer on the LAN facing interface where also it can be marked for some congestion avoidance and then apply the cbwfq policy that you have posted on the wan interface from some congestion management
Res
Paul
Kind Regards
Paul
Disclaimer
Posting
If I remember correctly, the later IOSs that support percentages on policers or shapers, I recall, should use its parent's bandwidth.
