Combining bandwidths on a router
fahim
The local ISP provides cheaper WAn links in the form of ADSL links, the cost of which is usually 1/3 of the leased MPLS based links.
Both of these terminate on the ethernet interfaces of a router.
I was wondering, if I can combine 3-4 ADSL links of about 4MB each to give me a total of 16Mb capacity for diverting my internal HTTP/SMTP traffic only, what kind of router setup should I be looking at?
How can my design cater to at least load balance the outgoing traffic across all 4 ADSL links while maintaining the incoming connections across the route?
Is there an extra equipment that needs to deployed apart from a router (2811 probably) with an extra HWIC of 4 FE ports?
HI Fahim, [Pls RATE if HELPS]
Please find the attachment having the details of Configuring Multilink P - to - P Method and its limitations for your reference.
If your LINK are Internet - Type, also from the Same Provider (ISP), request them to Bundle the LINK's at their side also.
Hope I am Informative.
Pls RATE if HELPS => Use the RATING System
Best Regards,
Guru Prasad R
guruprasadr
Level 7
Level 7
HI Fahim, [Pls Rate if HELPS]
The hardware is enough to support your requirement.
You can go for a "MULTILINK" concept. With Multilink the links are bundled and the traffic is carried over it.
This is a per-packet or per-destination load balancing. But in a Multilink the actual traffic is equally loaded on all the links that are bundled in the MLPPP.
Hope I am informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
Thanks Prasad, would take a look at this concept in detail, although a quick search for Multilink on Cisco site yielded Multilink results for all sorts of configuration and link classes. Can you pls help me identify the pertinant link?
So, using multilink, I effectively do away with using / enabling GLBP or HSRP/VRRP over any of my interfaces?
and, does enabling multilink on my router, requires me to involve the ISP side in any way?
Best Regards,
Guru Prasad R
